7 weeks ago I took my truck (07 KW T600 with CAT C15 Acert) to a reputable shop near me to have the engine inframed.
The last 2 weeks they have been trying to figure out why it's having oil pressure problems.
This engine has never, in the 5 or 6 years I've owned it, had oil pressure problems. And had good pressures when I dropped it off. I was having cooling issues. But nothing to do with oil. Turned out the engine had a cracked liner. So, the inframe was indeed needed.
So, after new liners, pistons, head, etc, the truck idles 10psi lower than the 22-25 it did prior. And won't get over 45 psi at 1300 rpm. They pulled the pan and 2 different people checked the bearing clearances. Which are good.
It was decided that the oil pump was failing. New oil pump. No change. Then they started hooking up mechanical gauges anywhere they could and noticed before the oil filter they got 80 psi. Immediately after the filter they got 40 or less. So, add in a new oil filter housing. Pressures came up. And all was well in the world.
UNTIL ... they took it for a test drive and the OIL pressure light came on.
That was just a little while ago.
They are scratching their heads. Meanwhile, my bank accounts are dropping like rocks having been off for 7 weeks.
If you have any ideas on what these guys can look at that might cause this problem, please let me know. I'll forward it along. Personally, I think one of the new parts in the rebuild was faulty. Which one? I have no idea.
Low Oil pressure after rebuild - NEED Your Wisdom!
Discussion in 'Trucks [ Eighteen Wheelers ]' started by RustyBolt, May 4, 2024.
Page 1 of 3
Is there oil control valve or is it built in the oil pump? Might be that
aljihada, RustyBolt and blairandgretchen Thank this. -
Piston cooling nozzles all in place? Pull the valve covers and run, look for excess oil flow from anywhere that looks abnormal? Engine brakes, rockers ect….
Double check suction and pressure tubes for cracks seal leakage or blockages.aljihada, Rideandrepair, wore out and 6 others Thank this. -
80 psi sounds pretty high pre oil filters.
I’m only familiar with 12.7 S60 and N-14 though.
One oil filter or two, and correct spec for that engine?aljihada, Rideandrepair and RustyBolt Thank this. -
What spec are you asking for? Uncertain. but I'll live dangerously and assume your talking oil pressure specs. Minimum (from a CAT graph I found on line) is 15 psi @ 600 rpm and 42 (ish) @ 1200 and up.blairandgretchen Thanks this. -
80 psi pre-filter and 40 psi post filter tells me your issue is beyond the filter. Something somewhere is either leaking or something has excessive clearances.
Like suggested above, running with valve covers off will let you see if something is leaking up top or if excessive oil is spewing out past a damaged rocker bushing/shaft.
Maybe there's a possibility there's a cam bearing issue or an oil galley plug somewhere that was loose/leaking and then it finally fell out and triggered a low oil pressure warning.Last edited: May 4, 2024
Jordonh, RustyBolt, Diesel Dave and 1 other person Thank this. -
RustyBolt Thanks this.
I'm not an "internal" engine mechanic. I'll change anything on the outside though. But, y'all probably figured that out already. I'm just trying to give them a list in the hopes it'll get them thinking about whatever the problem is. Like I said, the bank accounts are getting smaller. And the McD's here isn't hiring right now.aljihada and blairandgretchen Thank this.
Page 1 of 3
