Low Air Warning
Discussion in 'Trucks [ Eighteen Wheelers ]' started by JimmyWells, Oct 20, 2016.
  1. JimmyWells
    JimmyWells Road Train Member
    1,000
    1,078
    Apr 7, 2016
    I just picked up a 94 W900L and I was doing a brake check on it today. It's not giving me any audible nor visual warning at 60psi and the valve doesn't pop out at 20psi either. Anyone with a KW have any input?
  3. BoxCarKidd
    BoxCarKidd Road Train Member
    4,418
    6,431
    Aug 26, 2014
    In my opinion if you are down to 20 psi and the park brake valve has not poped out it is bad. Was that what you meant?
    94 KW is a bit new for me. However if you build air pressure, turn the engine off, turn the key on, drain primary or secondary tank, the light and alarm should come on. Repeat that process and drain the other tank. The alarms should also function. Know of trucks being put out of service for no audible warning and one had a light. Must have an audible alarm in my my opinion.
    Is it yours?
  4. JimmyWells
    1,000
    1,078
    Apr 7, 2016
    No light warning. No buzzer. No pop valve pop out. Nothing.
  5. baha
    baha Road Train Member
    4,137
    2,835
    Jul 25, 2013
    ga
    The low air warning switch should have 2 wires conn. by screws to a round switch thats put into air lines on the R. of steering col. under dash
    JimmyWells Thanks this.
  6. Blackshack46
    Blackshack46 Road Train Member
    What if he has a wig wag, and doesn't realize why the wig wag keeps smacking him in the head while looking at the dash for a light or sound.
    Chances are he doesn't have an aftermarket wig wag, but that would be f'n funny.
    snowman_w900 Thanks this.
  7. AModelCat
    154,264
    How many drivers these days would even know what a wig wag is?
    x1Heavy, snowman_w900 and Blackshack46 Thank this.
  8. Blackshack46
    Way less than you and I can imagine probably.
    I honestly only learned of a wig wag before my cdl, when I was learning to be a heavy equipment mechanic. We covered air brakes for a portion, and that's the first and last time I've seen an actual wig wag in operation. This is some 10 years ago.
  9. snowman_w900
    4,418
    81,024
    Nov 25, 2010
    So i wonder how the DOT man doing a level 1 would feel about a wig wag. "Sir, being a smartazz isnt going to help your inspection".....but sir, the truck was that way when i boughtit. I thought it was cool! Lol
    Blackshack46 Thanks this.
  10. JimmyWells
    1,000
    1,078
    Apr 7, 2016
    Thanks, I'll have a closer look tomorrow. Do you think the brake valves should be replaced?
  11. ryanbob1
    ryanbob1 Light Load Member
    121
    35
    Sep 9, 2016
    Try 4 way protection valve on the main air tank that could be faulty 56251-Supply-Truck-Brakes-4-Way-Circuit-Protection-Valve-1.jpg
