was wondering if they sell a low air warning device that's aftermarket? like screws into a pressure tank and comes with the lite and buzzer. Need to buy somethin like this asap. anyone have any ideas. The one in my kenworth W900B never came working , it doesn't lite up or make a sound, i rather install one and run new wiring myself[FONT=Trebuchet, Trebuchet MS][/FONT]
Low Air warning device. Aftermarket
Discussion in 'Trucks [ Eighteen Wheelers ]' started by truckman29801, Jul 19, 2013.
Hope you get it fixed before you get an inspection. Otherwise I think you will be put out of service until it is fixed. Why not try going to KW for the part?
Stewart Warner makes a simple 2 terminal buzzer/light combination that can be wired to work with any low air switch. You should be able to find one on Ebay or Summit Racing.
Thanks, all i need is for the truck to pass inspection this month, had a level 1a few weeks back but they missed the buzzer idk how so i will fix it now
Any pressure switch will work, along with a light and buzzer. Just google air pressure switch and look at them. With a simple relay a pursue switch from a shop compressor will work just a well. All you need is a power write to one terminal, the other terminal will feed the light and buzzer, instead of kicking the compressor on.
Martin -
LOL now my freightliner wont turn off the low air warning, i think im gonna try this
