Low air pressure switch
Discussion in 'Western Star Forum' started by Stick_Hauler, May 2, 2014.
  1. Stick_Hauler
    Stick_Hauler Bobtail Member
    May 2, 2014
    TEXAS
    I've started have problems with the Low Air Alarm sounding from time to time, yet the air pressure is 120 lbs. in both primary & secondary circuits.
    A quick look under the dash reveled 4 sensors. Any idea which might be the one for the reserve tank...?
  3. baha
    baha Road Train Member
    4,137
    2,835
    Jul 25, 2013
    ga
    You can ck. with a test light after finding the brake light switch, let air out of primary an ck. then secondary an ck. the bad wire with a worn spot in it will show up hopefully after you ck. under dash?
  4. Stick_Hauler
    May 2, 2014
    TEXAS
    I found the sensor on the right side of the brake pedal and removing one of the two wires silenced the alarm. I'm hoping I can take the sensor off and 'Unstick' it, but the local dealer doesn't have a replacement in stock, so I'll wait until I get home and have the parts in hand before I tear it apart. Thanks for the assistance...!
    baha Thanks this.
