low air break pressure warning devices.
Discussion in 'Trucking Industry Regulations' started by damil, Oct 30, 2015.
  1. damil
    damil Light Load Member
    171
    247
    Sep 23, 2012
    My audible alarm went out on a 07 vn volvo. it is part of the dash cluster and volvo says i have to replace the whole dash cluster. or have someone solder one in. will not be able to get this done till I get home.
    am I reading the reg right that only says I have to either have a audio or a visual warning device.
    or am I reading just what I want to see lol
    http://www.fmcsa.dot.gov/regulations/title49/section/393.51
  3. uncleal13
    uncleal13 Road Train Member
    3,797
    6,293
    Apr 9, 2009
    Humboldt, Sk
    Looks like it's either visual OR audible. The old trucks used to have a flag that dropped down in front of your face mounted at the top of the windshield. I think your truck would still give a light on your instrument cluster, that should still count.
    damil Thanks this.
  4. damil
    171
    247
    Sep 23, 2012
    yes a bright red stop sign comes on. and the rest of the brake test is fine just the audible part quit.
  5. mountaingote
    mountaingote Road Train Member
    2,026
    7,916
    Sep 22, 2012
    Long as one or the other works you are fine
    damil Thanks this.
  6. BoxCarKidd
    BoxCarKidd Road Train Member
    4,418
    6,431
    Aug 26, 2014
    This is a repeat of someone quicker than I am. The light is required for the deaf driver. The alarm is required for the blind driver.
    I never personally encountered a truck put out of service for a low air light, low air buzzer, yes.
    damil Thanks this.
  7. GasHauler
    6,257
    4,365
    Oct 23, 2005
    Vegas/Jersey
    I've driven a couple of those old trucks that had the flag that dropped down. When the air was gone it dropped down and on the flag it said "jump dummy".
    brian991219, tsavory and tucker Thank this.
  8. Inspector
    Inspector Bobtail Member
    41
    29
    Dec 21, 2013
    Upper Plains
    If the truck was made after march 1st of 1975, the low air warning has to comply with FMVSS No. 571.121. That says this: S5.1.5Warning signal. A signal, other than a pressure gauge, that gives a continuous warning to a person in the normal driving position when the ignition is in the “on” (“run”) position and the air pressure in the service reservoir system is below 60 psi. The signal shall be either visible within the driver's forward field of view, or both audible and visible.
    BoxCarKidd and damil Thank this.
  9. damil
    171
    247
    Sep 23, 2012
    Thank you inspector this is the statute I was reading but we had a driver get a warning for no audible alarm but his visual worked. I just wanted to cover my butt :)
  10. Inspector
    41
    29
    Dec 21, 2013
    Upper Plains
    FMCSA likes to put must be in complance of FMVSS...(federal motor vehicle safety standard), then they don't put in what that standard says in the FMCSR book.
    BoxCarKidd Thanks this.
  11. Raezzor
    Raezzor Quis custodiet ipsos custodes?
    1,412
    1,186
    Aug 1, 2009
    Columbus, OH
    lolwut.... blind driver?
