Loud bang from my rear end.
Discussion in 'Trucks [ Eighteen Wheelers ]' started by nhramember, Oct 19, 2014.
  1. nhramember
    nhramember Light Load Member
    86
    25
    Apr 2, 2012
    Here is the problem I was at the pilot in Mississippi and I went to move truck. I let the clutch and heard a loud bang. I got out and looked . I didn't drop driveshaft. I went to put it in gear and it would not move . The driveshaft is spinning slow . I licked the power divider in and it moved with no problem. I was sitting here today and got out to check. I can turn the driveshaft completely around by hand. Is it possible that I broke the yolk or and axle. I need some ideas because I'm gonna try to make it to Pensacola about 80 miles away with e divider locked in. Does anyone any good shops in Pensacola? Thanks
  3. Jerry12
    Jerry12 Heavy Load Member
    723
    282
    Sep 9, 2014
    Take it to the closest garage. think about the what if, i need a wrecker 60 miles away from the closest shop...expensive tow charge.
  4. Pool6710
    Pool6710 Medium Load Member
    662
    258
    Aug 10, 2014
    Minnesnowta
    Sounds like an axel went or part of the power divider exploded.
    if you can drain the front rear and check for metal I would.
    mine had massive chunks in it and had to put in a $2400 power divider.
  5. snowwy
    snowwy Road Train Member
    20,525
    13,261
    Jul 6, 2009
    his truck will move with divider locked in. but not with it unlocked. busted axle.
    i'm guessing you were either starting off on a very steep incline or releasing the clutch before the brakes were released. those are the two biggest reasons drivers pop axles. or you got stuck in some loose material of some sort.
    Ezrider_48501 and 04 LowMax Thank this.
  6. swaan
    swaan Road Train Member
    2,942
    4,374
    Jul 12, 2009
    BC canada
    I second the busted axle.
  7. swaan
    2,942
    4,374
    Jul 12, 2009
    BC canada
    They will bust or shatter at hub sending peices into your wheel bearings. I would get it towed if it was me.
    04 LowMax Thanks this.
  8. Skate-Board
    Skate-Board Road Train Member
    3,801
    3,995
    Aug 9, 2014
    Merrimack, NH
    Ya, you should get it towed. The tow operator will disconnect your drive shaft before towing it also. Going to cost you around $800.
  9. rebeloutlaw66
    rebeloutlaw66 Light Load Member
    199
    41
    Sep 2, 2009
    had a similar problem, I let the oil get too low in front rear end but got really lucky, it got the power divider only, the ring gear and pinion were not hurt, I locked power divider in and truck moved fine no noise or popping, so I would check power divider
  10. Skate-Board
    3,801
    3,995
    Aug 9, 2014
    Merrimack, NH
    I'm surprised nobody made a joke given the title of this thread
    magoo68 Thanks this.
