Lost control power
Discussion in 'Refrigerated Trucking Forum' started by Ltyrell08, Feb 10, 2020.
  1. Ltyrell08
    Ltyrell08 Bobtail Member
    Feb 10, 2020
    My reefer shut down and it said lost control power. Does anyone know about that?
  3. reeferwrencher
    reeferwrencher Medium Load Member
    556
    1,474
    Aug 4, 2018
    Check the battery and the connections,make sure they are tight.Make sure the maintenance switch inside the side door is switched on.If all that is ok then open the control box and check for 12 volts at the board,if so check for a flashing green led light on the board.
  4. BRTLLC
    BRTLLC Bobtail Member
    5
    May 20, 2022
    Hey I did all that. Everything is good. But unit will run for awhile then cut off again with the same message
  5. reeferwrencher
    556
    1,474
    Aug 4, 2018
    When it cuts out is there still 12 volts at the board?
  6. BRTLLC
    5
    May 20, 2022
    Hey I’m having the same issue with my unit. Can’t figure out what’s the real problem. Help
  7. reeferwrencher
    556
    1,474
    Aug 4, 2018
    Is there 12 volts at the board when it cuts out?
  8. BRTLLC
    5
    May 20, 2022
    Yes. Still 12 volts at the board when unit cuts off
  9. reeferwrencher
    556
    1,474
    Aug 4, 2018
    Ok well sounds like it's the board unfortunately.Do you have any other 210 or are you a single trailer operation?
  10. BRTLLC
    5
    May 20, 2022
    Single unit operation
  11. reeferwrencher
    556
    1,474
    Aug 4, 2018
    Ok,I was gonna suggest swapping the board with another unit.If everything else (connections etc.,)seem ok I guess you could buy aftermarket on line.Of course you can take it to Tk, make sure you ve got lots of money if you do that though.
