Lost a turbo boot....
Discussion in 'Trucks [ Eighteen Wheelers ]' started by brenes-built, Dec 20, 2011.
  1. brenes-built
    brenes-built Light Load Member
    157
    15
    Apr 14, 2011
    Vancouver, Wa
    Lost the turbo boot before the air-to-air on the turbo side.. My question is that should I be worried about the metal rings that go around the boot doing damage to my engine if any made it thur...?? I had to run a mile before making it to a rest area.. :biggrin_2552:
  3. HISPEED428
    HISPEED428 Light Load Member
    157
    21
    Mar 28, 2009
    Plum Coulee,MB
    Nope, those rings would never go thru the ATA...
    brenes-built Thanks this.
  4. Infrared61ranger
    Infrared61ranger Light Load Member
    149
    36
    Dec 15, 2011
    killeen,tx
    as long a they didnt break apart some crazy way you dont have any thing to worry about just replace the boot and the clamps and pressure test all boots and keep on rolling
  5. Superhauler
    Superhauler TEACHER OF MEN
    12,209
    100,737
    Jan 30, 2010
    keep stroking.
    i always carry a coulpe of extra boots and clamps with me, along with a whole lot of extra parts. i also double clamp my boots so if one fail the second one will hold.
  6. Coal Bucket
    Coal Bucket Light Load Member
    179
    74
    Nov 15, 2008
    Charm City
    You may know this all ready, but do not use any kind of lube to slide the new one on. My buddy did that once, lol, nothin like scrambling to get new parts get her back up n running make it a mile or two and pow! your new parts are lost on the highway never to be found and its time to start scrambling again.
  7. Superhauler
    12,209
    100,737
    Jan 30, 2010
    keep stroking.
    and when they go you swear you just blew your motor sky high. until the shock wears off and you hear it idling.:biggrin_2556:
    losttrucker Thanks this.
  8. Coal Bucket
    179
    74
    Nov 15, 2008
    Charm City
    Lol. Superhauler , its a terrible terrible feeling for a couple of minutes ain't it?? Lol.
  9. Tank33
    Tank33 Medium Load Member
    346
    108
    Jan 10, 2009
    British Columbia
    Ah yes, nothing like blowing a clamp or a hose.
    I remember hitting a rough bump on a highway in Saskatchewan in the middle of the night, at the exact same time I hit the rough spot one of my hose clamps blew, I thought the engine was done like a Christmas Turkey but it was a 5 minute repair.
    Always keep spare hoses, belts, and clamps!
  10. pullingtrucker
    pullingtrucker Road Train Member
    1,185
    598
    Dec 21, 2008
    Fostoria, Ohio
    I've lost a few clamps and hoses when I push the motor near its limits testing it. Usually the pressure was in the 65-70psi range and it has scared a couple of drivers that I was next to. It was pretty funny until I noticed the dent in my hood.
    A freshly installed boot and clamp is the most likely yo come apart due to the fact that the boot and tube have not adhered to each other yet. I trick I learned from tractor pullers is to spray both the tube and the inside of the boot with areosal hair spray...it acts like glue and will seal the joint but not make it a pain to remove later on.
    Flightline, rebel127 and Nevs Thank this.
