2021 INTERNATIONAL RH SERIES/ A26 ENGINE:INTERMITTENTLY DASHBOARD DROPS OUT MESSAGE OF LOSS OF COMM COMES ACROSS DISPLAY:E.C.M SCAN SHOWS LOSS OF COMMUNICATION FOR ABS/TRANSMISSION/ECM MODULES:ALL GAUGES LIGHT UP ON DASH BOARD AND CAN NOT READ ANY GAUGES ALL EXTERIOR LIGHTS WORK AND ONLY THING YOU CAN GO BY IS AIR TANK PURGE TO DRIVE TRACTOR BACK TO SHOP:ANY HELP WOULD BE APPRECIATED IF SOMEONE HAS EXPERIENCED THIS PROBLEM:
LOSS OF COMM-DASHBOARD DISPLAY
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by POP CAN, Jun 23, 2023.
It sounds like something is taking down the communication on the J1939 data link.
You need to test the data link with a multimeter. It could be a data link wire with the
insulation rubbed through and grounding somewhere. -
If you have a plug in EDL or telematics device, try unplugging it.
I had same issue on my 2019 LT prostar . Loss of comm no gauges working. I fixed issue myself. On front bumper a sensor works cruise control and let you know when close to another vehicle. Disconnect it and you shouldn't have any more problems. Just need to replace sensor if you want cruise control working again.
