Losing coolant and air bubbles.
Discussion in 'Ask An Owner Operator' started by Drsparkey3, Feb 8, 2020.
  1. Drsparkey3
    Drsparkey3 Bobtail Member
    24
    20
    Nov 30, 2019
    Have a 2012 DD15 losing coolant from top radiator cap, and have bubbles in the coolant tank. The bubbles appear to be coming from the hose on the EGR cooler. I'm hoping not an EGR cooler or head gasket. Any ideas?
    Rideandrepair Thanks this.
  3. Studebaker Hawk
    Studebaker Hawk Road Train Member
    2,962
    9,546
    Oct 18, 2010
    NW Indiana
    the cooling system is probably being pressurized by combustion gasses. Liner issue, head gasket, injectors are top contenders. Do not drive it any distance until you find out what the problem is. The longer you delay, the more damage will be done.
  4. Dave1837
    Dave1837 Road Train Member
    1,396
    4,335
    Nov 16, 2019
    Pennsylvania
    Head gasket most likely. The coolant coming out of the rad cap is usually a tell tale sign
    Drsparkey3 and Rideandrepair Thank this.
  5. Rideandrepair
    17,212
    55,862
    Aug 8, 2015
    I don’t know much about the egr cooler, but I think I’d prefer that over a bad head gasket. I do know, You can disconnect the discharge line from air compressor, carefull, loosen it first, let it bleed air out first, then remove it. Run Truck, if bubbles stop, air compressors bad. You also can pinch off the coolant hoses on air compressor, with flat vice grips, or loop one of the hoses, to the other on the block, isolating the air compressor. Either way should work. Don’t run it long without coolant circulating though, you’ll ruin a good compressor. Maybe there’s a way to isolate the egr cooler? I don’t know. But you want to eliminate any other potential source, before taking the head off. Usually a blown head gasket or cracked head, but not always.
    Drsparkey3 Thanks this.
  6. mhyn
    mhyn Road Train Member
    4,255
    4,510
    Dec 29, 2008
    Northridge, CA
    cracked or scored cylinder liner. … very common to pre 2014 engines... or sunk liner .
    if you will have cracked egr cooler you will have a coolant in egr pipes.. in the morning , before starting the engine, remove rubber hose that is on egr pipe and inspect inside...bad air compressor ? 0.1% of chances.
  7. baha
    baha Road Train Member
    4,137
    2,835
    Jul 25, 2013
    ga
    Run a sample of the oil that is in it now off to a mail order oil anil. place you can buy sample kits a truck parts store or T/stop, wait for it to come back to e/mail, If you know a shop that will pull the oil pan off and put pressure in rad. then they watch for coolant to drip out of liner pitting hole then turn eng. over 1/2 turn at a time till its been all the way around 1 turn, hope its just egr cooler bad letting ex. pressure in rad. most liners that have pitting will let oil get in rad.
    Rideandrepair and Drsparkey3 Thank this.
  8. JAD1024
    JAD1024 Light Load Member
    57
    21
    Apr 9, 2018
    What was your final outcome
  9. Drsparkey3
    24
    20
    Nov 30, 2019
    Believe it or not, nothing ever happened. Still running it as is. I had service work done to the APU and they must have gotten air in the system...
    baha, Rideandrepair and loudtom Thank this.
  10. loudtom
    loudtom Road Train Member
    1,717
    2,800
    Aug 26, 2016
  11. Rideandrepair
    17,212
    55,862
    Aug 8, 2015
    Best way to find out for sure is a pressure test. Test for leaks with 10 lbs of pressure, see if it holds. Start Truck, see if pressure builds. No more guessing.
    baha Thanks this.
