Loosing air pressure when engine is running.
Discussion in 'Ask An Owner Operator' started by Aaag, May 17, 2024.
  1. Aaag
    Aaag Bobtail Member
    10
    5
    May 17, 2024
    I have freightliner cascadia 2015 truck is parking .engine is running. slow air built 5 minutes to purge. Start loosing air and purge cycling every 1 minute. When shutting of the engine its hold the pressure. no stattic air leak .for fan cluch I have swith to cut off the air . No change.replaced new air compressor new discharge hoses new tank new air dryer and governor. On gagues the secondary gague start loosing air. Truck is parking and running no brake no transmission engaged.
  3. ElmerFudpucker
    3,729
    38,964
    May 17, 2024
    Sounds like you have an air leak.
    shatteredsquare Thanks this.
  4. Aaag
    Aaag Bobtail Member
    10
    5
    May 17, 2024
    I have ultra sound device for air leak checking .used while engine is off no air leak .
    silverspur Thanks this.
  5. Pepper24
    Pepper24 Road Train Member
    2,047
    1,558
    Dec 3, 2010
    Doesn’t sound like a leak more like a faulty governor or even the compressor it self.It’s been a long time I don’t remember exactly but there’s a needle on top of the one I had that will screw out and replace it that was on a cat I’m sure yours is different if it’s the governor you just replace it.
    bryan21384 Thanks this.
  6. Aaag
    Aaag Bobtail Member
    10
    5
    May 17, 2024
    Tomorrow I'll disconnect every hose connected to secondary tank an block it from tank . One by one .and see if I have leak or not.
  7. abyliks
    abyliks Road Train Member
    3,742
    8,691
    May 2, 2010
    ludlow MA
    Leak soap is still the best way to go
    check the lines coming out of the compressor
  8. Aaag
    Aaag Bobtail Member
    10
    5
    May 17, 2024
    New discharge line replaced from air compressor to air dryer.
  9. FLHT
    FLHT Road Train Member
    1,329
    2,260
    Aug 2, 2014
    The discharge hose from compressor to air tank tend to plug up over time.
    Make sure you use the right hose .
  10. 201773
    201773 Medium Load Member
    404
    615
    Dec 14, 2020
    I had the same problem with a 2019 Cascadia. Turned out to be a leaky air bag.
  11. Kenworth6969
    2,724
    7,827
    Jul 3, 2020
    Near 10 year old Crapcadia is on its last legs
