Loose leaf log binder
Discussion in 'Ask An Owner Operator' started by Dino soar, Dec 2, 2019.
  1. Dino soar
    Dino soar Road Train Member
    4,834
    27,114
    Dec 8, 2017
    I am looking for a loose leaf log binder. The ones on line seem a little junky.
    Is there another type of binder that would work with paper logs?
    truckinglife1198 Thanks this.
  3. Mike250rs
    Mike250rs Heavy Load Member
    881
    7,084
    Sep 24, 2019
    Raleigh, NC
    have you looked at staples or other office supply places?
    Dino soar and singlescrewshaker Thank this.
  4. Final Drive
    Final Drive Road Train Member
    1,573
    2,507
    Jan 21, 2015
  5. singlescrewshaker
    5,078
    44,885
    Dec 31, 2017
    Little Havana, FL
    I just use a standard 1" 3 ring binder from any office supply joint.
    I also use the loose leafs that are the same size as a standard piece of notebook paper. Rods on top, ifta lower left, & dvir lower right..
    exhausted379 and Dino soar Thank this.
  6. DUNE-T
    DUNE-T Road Train Member
    7,103
    17,325
    May 10, 2015
    Detroit, MI
  7. Dino soar
    4,834
    27,114
    Dec 8, 2017
    That looks like the better of them, but I don't see the actual RoadPro logs that you would put in there.
    I guess there would be a JJ Keller log you can put in, but I don't know what size or what number.
  8. FoolsErrand
    FoolsErrand Road Train Member
    2,876
    12,170
    Sep 15, 2017
    3 ring binder here. DOT no issue with it. JJ keller full sheets with just time/destination log filled out. Inspection left blank, no recap hours page.
    Dino soar Thanks this.
  9. Dino soar
    4,834
    27,114
    Dec 8, 2017
    Is that an eight and a half by 11 binder?
    Is there a specific JJ Keller log that you use for that?
    That's the whole problem. Finding the right log for the right binder as I'm not looking at them right in front of me.
    singlescrewshaker Thanks this.
  10. HoneyBadger67
    2,056
    4,512
    Dec 15, 2018
    Savannah, TN
    Buy loose leaf logs and whatever binder you fancy along with a hole punch. Use the punch to put the holes in line with the rings of the binder and go forth and conquer.
    Seriously, it seems some people really feel the need to over complicate things. When I ran paper, the logs came stapled together. A knife or pliers took care of the staples and I did just as I outlined above. It ain't rocket surgery, ya know.
  11. snowwy
    snowwy Road Train Member
    20,645
    13,372
    Jul 6, 2009
    When I ran paper. It was on laptop. And printed and turned in to office.
    Backup was synced to the cloud.
