hi everyone, my 2012 Volvo has 500k miles and I recently changed the output shaft in the rear. Now the middle axles Differntial is loose. Iv had the truck for about a year, ALWAYS use a landing gear. what can it be inside thats making it loose?
Loose Differential
Discussion in 'Volvo Forum' started by AlexD13, Jun 17, 2016.
Thrust washers wore out maybe
when you say middle differential are you talking about power divider if so they get loose all the time nothing really new one thing you do want to check is if the slider is working properly sometime if they don't they will make weird noises on uphill and downhill also make sure you check your ride height that it is set properly
KB3MMX Thanks this. -
There should be zero play in out put shaft. If there is needs new bearings. Just did my w900. Had play no leak on seal. But changed anyways being I just dropped new rears in.
Yah , i figured it be that. How much would the new bearings cost me?
New lock nut and bearings an race with seal. Was about 175.00 that's for my W900. The shaft was fine even after using a cutting torch for the races. Need a big socket for the lock nut.
