Hello Everybody,
Im looking to get log books printed out with my company name and address on it, but I dont want to put my home address.
Can I put a PO box address for the home terminal?
Would DOT/ Scales have a problem with that?
logbook question
Discussion in 'Ask An Owner Operator' started by Rich_Trucking, Apr 21, 2014.
No, Not a problem at all....I use Pre-printed myself, Home terminal address is my Leased Parking Lot
Some of us use a logbook program. u can enter carrier name and.and address and simply print your logs each day. No need to special order preprinted logs.
i use trucklogger. the favorite seems to be drivers daily log. there's also eclipse.
some are even using bigroads on there phone or tablet. there's also keep trucking.NavigatorWife Thanks this. -
as opposed to log books, you should use a loose leaf log and order them w/your desired name and address.the stress eliminated will be worth the extra expense IF there even is a difference in price.i think keller & associates or similar can get you started or at least give you ideas.
i use a loose leaf log and the ones I buy from the TA are around $3.00 or less,are made in the United States,and separate so much more easily than what pilot and flying j sell.those are chinese made and you can tell it.The difference is astonishing.plus the USA made are easier to fill in and use.NavigatorWife Thanks this. -
http://www.driversdailylog.com/ works great easy to print off copies
