log book missing vehicle inspection form
Discussion in 'Flatbed Trucking Forum' started by keepontrucking81, Jul 15, 2013.
  1. keepontrucking81
    keepontrucking81 Light Load Member
    210
    41
    Jun 27, 2013
    Chicago, IL
    Man I just bought a bundle of log books but I noticed when I'm writing my log for today that on the back of the page it doesn't have the form for your vehicle inspection ..
  3. 25(2)+2
    18,749
    45,385
    Sep 18, 2006
    the road less travelled
    We have been using inspection books printed by Keller, and our logs have not had the inspection on the back for at least 7 years. When you pick up the books or loose leaf forms, you need to pick the ones that have the inspection part included if you want to use those.
  4. Chinatown
    Chinatown Road Train Member
    73,270
    164,630
    Aug 28, 2011
    Henderson, NV & Orient
    Most truckstops have vehicle inspection report forms, either in loose leaf or a book similar to a log book.
    25(2)+2 Thanks this.
  5. keepontrucking81
    210
    41
    Jun 27, 2013
    Chicago, IL
    Wont DOT write you up for not having inspection report?Im new just got my cdl
  6. Noggin
    Noggin Road Train Member
    2,494
    977
    Apr 10, 2011
    Houston, TX
    Yes they will. But it does not have to be attached to your log. just keep a separate book in your truck with your logs. Some logs don't have inspections because some companies have trucks that drivers share, so instead of the VI on the logsheet, they just have a book that is left inside the truck so the next driver to use it can fill it out and have the previous 7 days inspections..
    keepontrucking81 Thanks this.
  7. HORIZON2819
    HORIZON2819 Bobtail Member
    48
    14
    Nov 26, 2012
    Toronto,ON
    Inspection page is the most important page in logbook ... You have to fill the info on this page upon inspecting your vechicle.. It tells that you have inspected your vechicle and ensures it is safe to drive on road... If you dont have this page or dont fill it then it clearly indicates that you have not inspected your vechicle i.e. PTI .. Not only DOT but any sheriff on street can give you a big ticket and put you on out of service and might charge you for careless driving ... Good luck
  8. Noggin
    2,494
    977
    Apr 10, 2011
    Houston, TX
    But you do NOT have to have it attached to your log book.
  9. HORIZON2819
    48
    14
    Nov 26, 2012
    Toronto,ON
    Thats right ... As long as you have done it right .... They will inspect you on based of your inspection report..
  10. coastie
    coastie Road Train Member
    WOW many years I never touched it and never was hit on it during a DOT. Only till I worked for USA I did it. Guess I was lucky
  11. SamTheMan
    SamTheMan Light Load Member
    155
    69
    Jun 20, 2013
    One exemption..... If you are a one truck operation with your own authority. You do not have to do a daily DVIR.
    Terrain and cetanediesel Thank this.
