I dive under the short haul exemption 90% of the time, but once every few months I’ll venture beyond the 150 mile radius.
My question is, how do I fill out my log book when I go beyond 150 miles? What I’ve done in the past is get a new log book, and back-fill out the last 7 days, but I wonder if this is necessary? I know long haul drivers have to have the last 7 days available, but it’s that required for a short haul driver who has to log once every few months?
Can I just fill out the day in question, and does it have to be a new log book every time I have to log miles? I don’t want to have to do more than I have too, but also don’t want to get stopped and cited for not doing it right.
Local driver going beyond 150 mile radius
Discussion in 'Trucking Industry Regulations' started by m16ty, Jun 12, 2024.
I would use one page and write at the bottom that I was local within the 150 mi limit for the past days. Show a range in dates covering the dates.
No, it does not need to be a new book. You only need to complete the log for the day(s) you do not qualify for the short haul exception. Once you realize you do not qualify you create a log from midnight of that day forward until you have taken a 10 hour break back at home and again qualify for the short haul exception. When I was running short haul exempt I would have months of logs in the same book, never was a problem.
Here is a link to the FMCSA guidance on the subject, which is so old it still refers to the 100 air mike radius, however it is still valid.
https://www.fmcsa.dot.gov/regulations/hours-service/3958-q20Feedman, Long FLD, m16ty and 1 other person Thank this. -
I fall under that exemption rule, I have a 31 day hourly sheet and fill out my hourly time for each day. When you run outside your radius,(I have loose leafs logs)I just fill out my paper log(book)and that’s it. The next day when your local again, I go back to my hourly daily log. This sheet I use has a box at the end, you check that when you use a paper log.
Feedman and Diesel Dave Thank this.
Diesel Dave and Feedman Thank this.
How often are you allowed to use it , 1 day in 8 outside the local area ?
