Local companies and DAC
Discussion in 'Questions From New Drivers' started by JudahMourn, Apr 19, 2016.
  1. JudahMourn
    JudahMourn Light Load Member
    55
    15
    Jan 16, 2016
    Do the local food and beverage and waste management type jobs check DAC?
    I'm looking to start applying to these companies now that I have my 1 year complete.
    I fear my current employer will put something on my DAC for retaliation for leaving/quitting.
  3. David_Simpson
    David_Simpson Medium Load Member
    650
    637
    Feb 23, 2016
    if you mean like, Coke, Pepsi, Waste Management, BFI, then yes, as they are nation wide.
    if you happen to live in an area where there are beverage companies NOT in any way connected to the above, then most likely no.
    JudahMourn Thanks this.
  4. 123456
    123456 Road Train Member
    10,555
    5,745
    Oct 22, 2010
    32179
    A common misunderstanding of DAC.
    Some companies only use it for verifying experience/past employment dates,
    and pay little to no attention to all the other crap on it.
    Some companies even view it as a waste of time.
    Check your DAC often for errors, they make a ton of them,
    especially if you have a common last name.
  5. JudahMourn
    55
    15
    Jan 16, 2016
    Makes sense. May just check employment dates and disregard any,if other crap. I just ordered a copy of mines.
    123456 Thanks this.
  6. 123456
    10,555
    5,745
    Oct 22, 2010
    32179
    Good Luck
    You'll find a job.
  7. JudahMourn
    55
    15
    Jan 16, 2016
    Hope they don't add anything to put me through the removal process. These mega carriers suck!
    123456 Thanks this.
  8. ChaoSS
    ChaoSS Road Train Member
    3,338
    6,755
    Sep 20, 2014
    Why do you think they would put stuff on there? Some times you may run into petty people who do petty stuff, but if you don't cause problems, and you get your truck back to the yard when you quit, the megas have better things to do than make up false info that could get them sued.
  9. WisconsinF150
    WisconsinF150 Light Load Member
    297
    213
    Dec 21, 2014
    Poly Trucking doesn't put anything on your dac. Not sure if they review dac or not though before hiring.
  10. Moose1958
    Moose1958 Road Train Member
    15,091
    33,175
    Dec 17, 2010
    Williesburg, Virignia
    Be careful with that advice. Have you ever seen what is returned when a history is asked for? I have, it is sorted by company and the information is brief but concise. Not only do the companies that use DAC look at the information they also pull DACs for the yearly review. The DAC report is formatted in such a way someone with experience can get a general idea if they will hire or not in just about 2 minutes. I won't defend my remarks but will challenge anyone that doubts them to contact your HR/safety dept and ask them!
  11. Moose1958
    15,091
    33,175
    Dec 17, 2010
    One more thing about DAC. It is true a lot of small companies don't generally pull DACs but a drivers DAC file is available if requested. The company that maintains the DAC database is a business that makes money on every report they provide. If Outlaw trucking who operates 3 trucks has a doubt about a new hire they can go onto the DAC website and order an ad hoc report. It is easy and not that expensive. I have seen it done.
