Loading Racks
Discussion in 'Tanker, Bulk and Dump Trucking Forum' started by Transit_lifer, Feb 23, 2020.
  1. Transit_lifer
    Transit_lifer Light Load Member
    143
    86
    Feb 23, 2020
    Hemet, CA
    Im looking into fuel transport and ive heard of being trained or certified on different fuel racks for different locations. Are they all the same or just a different procedure going through the prompts? Also, ive heard that some are worse than others to load up at.
  3. truckdriver31
    6,989
    8,352
    Sep 18, 2013
    i heard you want all your fuel rack cards
  4. Transit_lifer
    143
    86
    Feb 23, 2020
    Hemet, CA
    So there's different ones for every terminal?
    truckdriver31 Thanks this.
  5. truckdriver31
    6,989
    8,352
    Sep 18, 2013
    i guess. i dont really know. once checked into fuel years ago. the guys i talked to said its all about the rack cards
    tscottme Thanks this.
  6. RoadRooster
    RoadRooster Road Train Member
    4,121
    6,709
    May 10, 2015
    Fort Myers, Florida
    There can be many vendors at any tank farm. You must be certified on each one. They issue you a card. You use the card to fire up the machine. Enter a few digits on a touch screen and whoosh your tank gets loaded. Every vendor is slightly different but basically the same info.
    If a tank farm has a dozen vendors, your company will probably only use a few. So you might have 3 fuel cards for loading.
    truckdriver31 and tscottme Thank this.
  7. andhe78
    andhe78 Bobtail Member
    43
    75
    Jul 11, 2017
    Buffalo, NY
    I just moved to fuel hauling last year and had to go through the certification process to get carded at eleven different racks. While every rack has similarities, they all have their own quirks and regulations. Some only needed three loads with a trainer before you were carded, while a couple needed more than ten loads. Some places want a walkaround, some you have to wait for the security gate to close, some you have to check in with the loaders, etc. The one real constant everywhere seems to be fr clothing and hard hat/safety glasses. The actual process of hooking up the arm is the same everywhere, but every one of our racks has a different computer system they use. Another thing you need to know on night shift is when and how long each rack is shut down every night for inventory, every one of ours is different. It’s not a hard job, but I made sure to write everything down for each place. After a dozen loads at each rack, their particular procedure will become second nature.
    speedyk, 91B20H8, MrJoop and 5 others Thank this.
  8. meechyaboy
    meechyaboy Heavy Load Member
    794
    1,226
    Oct 4, 2018
    Detroit, Michigan
    Yea they’re all the same yet they’re all different. The actual rack themselves are 99% the same. Scully- loading arms - vapor recovery. Slight differences in the loading heads. The differences are gonna be the muster points. What to do in emergency situations. Where your estops are located. You may have to sign and drop a bol in the box. Some places you can do a split load in the computer without removing your card. (Training and preferably writing down and double checking will prevent overflows)It’s all the same but different at the same time
    speedyk and MrJoop Thank this.
  9. meechyaboy
    794
    1,226
    Oct 4, 2018
    Detroit, Michigan
    Also once you get your first card the rest of the cards come easy it’s like taking the same test over and over again. Also some places just turn your card on after you load with a trainer so many times. Places that have multiple locations may even turn your card on after they know you’ve been carded at one of their other facilities. For me Sunoco just needed to see three bills signed by a terminal operator and it was turned on at 2 locations. Got carded at one marathon, the other one just wanted to watch me load unassisted.
    MrJoop Thanks this.
  10. RockinChair
    RockinChair Road Train Member
    4,919
    12,258
    Feb 19, 2012
    CC, TX
    Anytime you get carded at a rack, ask the operator what their procedure is if you Scully out. Because they are all vastly different.
    We have three racks where I live. At one, if you Scully out you are finished loading. Take your BOL and go, and don't come back for 2 weeks because you're locked out.
    At another rack, you take the arm off and drain enough fuel out of the compartment to make the sensor light turn off. Then you wash the fuel down the drain with a water hose and load your next compartment.
  11. Exit310
    Exit310 Medium Load Member
    537
    244
    Jul 13, 2011
    cullman,alabama
    What is the term meaning"if you Scully out'?
