Hey guys - I'm an architect, designing a loading dock - it's an underground facility, so the trucker has to drive down a ramp, past the dock, and execute a 90 degree turn backwards to get up to the dock. The turn is such that the driver can see the back of the truck out the left window.
The dock length is 60' and there's an additional 70' of maneuver space in front, for a total of 130' of space. the trucker can pull up so the nose of the truck is 85' past the edge of the dock, which is what I'm having trouble with. I expect that the trucks that come here will probably NOT be long haul trucks, (I expect more local or regional type delivery) however, I hope to design it so that the largest trucks can use it.
So, my question - how far past the dock does the truck need to pull to execute the 90 degree turn? and how much horizontal space will they need? (side to side of the truck)?
If the 85' isn't enough to make it easy, can it be done with multiple turns - within the 85' space? I'd assume this would require more space side to side.
loading docks - how tight can an 18wheeler back up?
Discussion in 'Questions To Truckers From The General Public' started by architect, Mar 12, 2007.
Page 1 of 3
This depends on how many spaces that will be built. If this is the only dock in this area and no cars will be parked down there, which is very common in underground structures I used to encounter when I hauled freight. It sounds like enough room for daycabs with 53 foot trailers but tight for the long haul super trucks. We appreciate your thoughtfulness for us truckers. If more designers thought of us when designing delivery areas, our job wouldn't be as stressful. Thank you!
Sapper Daddy87 and libertasvelnex Thank this. -
We're planning on having 2 dock spaces for large trucks (semis) and 2 dock spaces for shorter (straight body) trucks. There will also be 2 van spots & a load/unload for 2 dumpsters - so a total of 8 spaces, but just two for the large trucks. No public access though. I'm guessing that it'd make sense to pull the shorter vehicles back as far as possible, so the bigger ones have more maneuver room. thanks!
Sounds like it would work. It would be tight, but an experienced driver should be able to pull it off. Another thing to remember is to make sure the truck will have enough room to swing out around another truck next to him after he gets loaded/unloaded with the other driver still getting loaded/unloaded next to him. The average over the road truck lenght is around 70-75 feet, give or take a few feet, but day cabs are much shorter and have a shorter wheelbase for better close quarter backing and turning....hope this helps a little.
And thank you for making it a sight-side back(can see the trlr out the left hand window). Nothing worse than getting somewhere new and you've gotta blind side it into a teeny spot.
Sounds like it might be a little tight for the LLLLOOONNNGGG nose OTR trucks but it should be manageable. -
yes you have to allow for backing in next to a truck and trailer not just a droped trailer. it could help if you placed the straight truck docks between the two semi docks so they have more room to swing. Alot of the math will depend on how close together the docks are too. I once picked up at a disney warehouse in CA that had the docks so tight together I had to get someone to crawl under the trailers on either side to hold my dors tight against the trailer or I would have taken off the doors of the other trailers. In that case I had to have enough room in front of the trailers on ether side to fit the entire truck and trailer since it had to be perfectly straight before backing in. If you understand that. The rear of these 53 foot trailers swing a ton when the tandems are slid up
If at all possible I would think that having 100ft of space in front of the dock space (which should also be at least 70ft to accommodate a tractor trailer w/a 53' trailer) would be a minimum to execute this dock maneuver. Unless I'm just thinking entirely wrong, this dock would be a nightmare for drivers of anything more than a spotter truck (such as an Ottawa). Even day cabs might struggle with this one, especially when pulling out of the dock after loading/unloading as someone else already mentioned. Speaking for only myself, let me know where this dock is so I can do everything in my power to never have to back into it.
Do you have a drawing of what the dock area might look like....
K -
How tight can a truck turn while backing up??
UNTIL IT JACKNIFES!!
Page 1 of 3
