"Loaders" at dairy farms.
Discussion in 'Tanker, Bulk and Dump Trucking Forum' started by bentstrider83, Jan 19, 2019.
  1. bentstrider83
    bentstrider83 Road Train Member
    1,722
    1,641
    Dec 26, 2011
    Portales, NM
    I've done the "loader/driver" thing for a couple of years and while it was okay, the ever-changing schedule each day made me get out of it and into the shuttling gig. But enough about me. Are there any dairy farms or milk hauling operation where there's a strict "loader" that hangs around at the farm and just loads tanks that get backed to the hose port?
    I know WDT employed people like that who simply drove a company pickup around to different dairies and met with the drivers over at each one to get them loaded up. But then I guess some outfits wanted to cheapen it all and decided to have the driver's do both jobs, drive and load the product.
    cuzzin it Thanks this.
  3. x1Heavy
    x1Heavy Road Train Member
    34,017
    42,129
    Mar 5, 2016
    White County, Arkansas
    No.
    When I hauled milk, I put the hose to the tank with filter. And agitate the tank prior to getting the weight measure for the clipboard under state license. That determines how much milk is being picked up. In addition there is a quality check of the milk. Bad milk never goes into the trailer and ruin the rest of it.
    Once everything is in order and the weight taken flip the switch and pull the product into the trailer and done.
    Drive to the next farm. Easy. No helper needed or wanted.
  4. bentstrider83
    1,722
    1,641
    Dec 26, 2011
    Portales, NM
    I guess I got burnt out with dispatch tossing 2-3 extra barns on top of the 3-4 I already had scheduled. 14-18 hour nights and a whole lot "bite the tongue". Only way I'd go back to it is if I was on one of those 18-20 hour, single barns that was 200-odd miles away. Made my own schedule up on that one. And it was also a single broker, as opposed to a co-op bureaucracy, that we dealt with. Now THAT was an easy set up.
    Select and DFA co-ops are like "running the trains on time". That and I could be considered one of those "slow guys" that got clowned on. Hence the preference for 1-2 barns a night.
    And if a particular company attached to a set of barns ends up being late and spilling milk, the co-op just simply finds another carrier and hopes for the best. The carrier that spilled has dairies eliminated and gets put into a sort of "doghouse" as punishment. At least down here.
  5. snowwy
    snowwy Road Train Member
    20,526
    13,261
    Jul 6, 2009
    I don't know about WDT but the farmers typically load the DFA and Tilden trucks. Could be the drivers too. I"m not sure. I see their trucks but never any pickups like what your saying WDT does.
    I thought about hauling milk. But then i see the plant broke down and trucks stacking up. Most of the trucks that haul are from idaho and live in idaho. They can't go home till they make delivery.
    bentstrider83 Thanks this.
  6. x1Heavy
    34,017
    42,129
    Mar 5, 2016
    We were on a fixed assigned route. I took care of 6 farms one day and 7 on alternate days in two counties. All of the output went to Greenspring in Baltimore off Jones Falls. On weekends those drivers ran the route. Every truck had a fixed day and usually a full trailer more or less depending on how the cows were doing.
    Dairyman's in maryland (Sykesville) were the oracle that decided who got what milk, where, when and how much. Some farms were tiny only 2000 pounds others were truckload farms. Get the whole trailer in one stop.
  7. bentstrider83
    1,722
    1,641
    Dec 26, 2011
    Portales, NM
    That was what they used to do according to somebody I know that used to work there. From the standpoint of an alternative job, a strict loader running around in a pickup would be an excellent choice for someone down on their luck, CDL wise anyway. I'm not, in case anyone wondered.
  8. bentstrider83
    1,722
    1,641
    Dec 26, 2011
    Portales, NM
    I forgot about those operations where one trailer was used for multiple dairies. Still pretty intriguing to hear about.
    Out here, it's not unheard of for most company driver-loaders with any given outfit to be thrown 4-6 barns a night. Anywhere between a 1 hour to 4 hour turnaround(drive time there and back, plus prep and pump time), and a full tank from each barn. And then most of these farms usually had 2-4, 7,000 gal silos that would each get filled within 3-5 hours.
    Don't know the exact number of dairy farms in the west TX/eastern NM area, but shorthandedness, general fatigue, and finger pointing tends to run rampant with these factory farm ops out here. Couple that with lack of clean tank trailers, a barn running behind or ahead, or the one of the plants running slow, and it's a recipe for pandemonium
    It's a rat race, that's for sure.
    x1Heavy Thanks this.
  9. x1Heavy
    34,017
    42,129
    Mar 5, 2016
    It's one dairy instead of multiple.
    We had no politics finger pointing or nothing like that. You were supposed to be at farm one at 5 am to collect the milk in the timely manner and move on to the next. Each farm is depending their entire milking and day around your trucks arrival. And regardless of weather, you will be there. That's really all there is to it. That and good samples taken. If you failed in these two simple things then you were fired and replaced instantly.
  10. bentstrider83
    1,722
    1,641
    Dec 26, 2011
    Portales, NM
    Firings and replacements got so common around here, it was usually bouncing back and forth between multiple companies every few years. Sometimes, a driver fired from a particular company would weasel their way back over to that same place after a couple of years due to a change in management.
    Turnover is pretty heavy with most milk hauling outfits around here with the consistently changing schedules wearing people down. But on the other hand, drivers tending the whey protein and liquid feed are quite happy. Set schedule, same route, and not a whole lot of pressure. Coupled with higher pay and faster trucks, life is gold on that side of the food grade table out here.
  11. tommymonza
    tommymonza Road Train Member
    4,519
    12,848
    Sep 10, 2013
    S.W. Florida
    Find a company like mine. Multiple trailers loaded and waiting for 400 mile delivery’s.
