It is legal or illegal on an Alum trailer to wrap your chains around the pocket and then hook it in the pocket and with the bracing from the rub rail to the trailer. Can you go around the bracing and hook the chain to the rub rail? Is that proper load securement?
Load Securement
Discussion in 'Flatbed Trucking Forum' started by ILtrucker62271, Jan 26, 2012.
Page 1 of 4
Same as on a steel rub rail. As long as your chains stay inside the rub rail and use either the stake pocket or spools you're fine. I suggest using the spools because the corners of the pockets get torn up using them on aluminum rub rails.
VisionLogistics, Glimmer, jldilley and 3 others Thank this. -
Also depends on the brand of trailer. Reitnouer pockets aren't welded to the trailer, only to the rub rail. They're only clipped into the side rail, kinda scary if you choose to use them as an anchor point. -
Check the trailer manufacturer's literature. They will tell you the anchor point and WLLs.
Not all trailers are equal.
But you loop around the spool or the pocket and hook the chain to itself. I've seen guys hook to the pocket and that is a no-no.jldilley and Mommas_money_maker Thank this. -
Reitnouer must have changed at some point. My pockets are welded on the back side as well now.SHC Thanks this. -
I would say a stake pocket isn't designed to have a chain hook on one side of it. It is weaker this way and not worth the full WLL.
It is designed and rated to support the chain as a whole and not just one side of the pocket.
And the cops want the chain hooked to itself.
Take your chances...
I ain't no engineer even though I sometimes go WOOO! WOOO! CHUGGA! CHUGGA! CHUGGA! CHUGGA! when I'm driving.Mommas_money_maker and jldilley Thank this. -
I was partially incorrect. It depends on whether you have steel or aluminum trailer.
This from Fontaine
"Figures 1 thru 9 are representative of the methods used for testing standard anchor points."
See fig. 1,2,5 and 6 all have WLL of 5400 lbs. for steel trailers. However fig. 5 with chain hooked onto side of aluminum pocket only has WLL of 4,000 lbs.
http://www.fontainetrailer.com/pdfs/trailer-operator-manual.pdfGrumman, BORNtoROAM, jldilley and 1 other person Thank this.
Page 1 of 4
