Load Securement - Chains, Chain Binders - Straps
Discussion in 'Heavy Haul Trucking Forum' started by UltraZero, Jun 7, 2014.
  1. UltraZero
    UltraZero Medium Load Member
    406
    96
    Jul 18, 2013
    Good day. I was wondering....
    How many people have had issues with DOT regarding the labeling of the WLL of chains, Chain binders and straps.
    Example - If the clevis on the chain states 3/8" Grade 7, is this enough for DOT or will he chain need be stamped
    on every link G7 3/8"
    The straps normally have WLL of (examle 5400Lbs) so not really worried about the so long as the label is on the
    strap or so long as the strap is stamped with WLL.
    Chain binders, same question.
    Thanks
  3. Richter
    Richter Road Train Member
    4,090
    1,700
    Feb 13, 2012
    Philadelphia Pa
    all just need it stamped somewhere, not each link...but keep inmind, if ur binder is not as strong as your chains, its the week link
  4. leftlanetruckin
    leftlanetruckin Road Train Member
    3,607
    3,160
    Mar 12, 2009
    Mo Via Blackpool,Lancs.
    Chains should be marked every "1 to 3 feet" with the manufacturers grading.
    Binders will have it right on the handle.
    This is of course ASSuming you have decent stuff, and not made in China junk where the stamping isn't worth a hoot. I have seen them snap, it isn't pretty. I also will not use junk lever binders, a ratchet binder is so much easier, to both secure safely, and not damage the freight.
    With the stuff I use (13,000lbs WLL), the trailer is normally the weakest link if it isn't an RGN.
    Check the sticker on the trailer, if it's still there, to see the WLL of the stake pockets etc if it is a flat/step. If an RGN, then it will be for D rings, cutouts, etc.
    Whatever is the lowest number (chain, hook on the end, binder, tie down point), that is what you will get credit for if inspected. No point using one of my 1/2" chain and binders on a crappy stake pocket rated for 6,000lbs, as it would just drag down my 13,000lb chain/binder rating to the 6,000lb stake pocket rating.
    Martin
    MartinFromBC and reddove Thank this.
  5. UltraZero
    406
    96
    Jul 18, 2013
    I noticed the 3/8th chain i have only has a stamp on the hook. I haven't check to see if there are more stamps on the links.
    My binders are 3/8 - 1/2 ratchet binders..
    I don't want to use snap binders. I think they are dangerous. I know they are quicker, but, one wrong move and snap. broken face or arm. Not to mention, if
    you put the bar in incorrectly, it will go flying...
  6. leftlanetruckin
    3,607
    3,160
    Mar 12, 2009
    A QUALITY 3/8 binder will be rated for 7400lbs. Cheaper ones are 6600lbs.
    The 5/16' necklace chains, which are all but useless in my experience, are 5400lbs IIRC.
    The hook stamping is just for the hook, as they are removable. The chain will (should) be stamped every few feet. Older chains though, wont have it. So long as it's a quality piece of chain, it's fine in my book. I have seen newer Chin junk break at the welds, where one of my old chains has not even stretched.
    Martin
  7. Mudguppy
    Mudguppy Degenerate Immoralist
    1,657
    4,064
    Apr 28, 2014
    Wooley Swamp
    Also, keep in mind that ANY link in a chain, or link from binder to hook, that is even slightly disfigured should be immediately discarded. Not only will it be a ticket, but more importantly could be the warning sign before a catastrophic failure. Really bad Ju-Ju....
    Richter and sly1 Thank this.
  8. Richter
    4,090
    1,700
    Feb 13, 2012
    Philadelphia Pa
    To clarify, if the chain hooks are removable the links should be rated somewhere to. We buy chain with non removable hooks and thus its all one piece. They only rate the hook becuase it is not removable from the chain.
  9. UltraZero
    406
    96
    Jul 18, 2013
    My chains are stamped 3/8 and/or g70 every 8th link.
    Clevis's are removable and are stamped 3/8 and g70.
    MartinFromBC Thanks this.
  10. Oscar the KW
    Oscar the KW Going Tarpless
    12,246
    28,114
    May 19, 2011
    I wouldn't want a chain with non-removable hooks, sometimes you need to take the hook off to get it thru a hole on a piece of equipment. If all you ever haul is general freight, steel, etc. then they would be fine.
    passingthru69 and Lucar Thank this.
  11. rank
    rank Road Train Member
    9,916
    113,498
    Feb 11, 2010
    Yep. I have been given various degrees of grief for:
    -GR70 on links not legible (this is a real PITA).
    -WLL in strap tags not legible (have since stopped using straps with tags)
    -bent link (I check them now)
