Load locks for beer loads
Discussion in 'Experienced Truckers' Advice' started by JC1971, Jul 28, 2021.
  1. JC1971
    JC1971 Road Train Member
    2,607
    9,293
    Jul 29, 2013
    L.A.
    Went to Miller Coors today. The geniuses who loaded it, when they inflated the airbag, it pushed the beer against the side of the trailer so I couldn't get load straps on it. I asked them to move it away from the side and they told me "If we deflate the airbag, you have to sign a waiver taking liability." Of course I refused. My company wouldn't say they would take responsibility.
    So, now using load locks is my only option. The one time I used one, it fell off before I reached the consignee. I would think this would potentially be worse than deflating the airbag a little and using load straps. Any suggestions?
    All I can say is F Miller Coors sideways.
  3. 062
    062 Road Train Member
    6,141
    33,149
    Oct 20, 2013
    What I do is place one end up against freight and the other about 4-6” away,then latch load lock, then use another to bang both ends tight to the freight.
    You can also put a load lock up, then place another directly below and latch it. Be ready to catch the first one.
    Malt Ball Cult, JC1971 and Dockbumper Thank this.
  4. truckdriver31
    6,989
    8,352
    Sep 18, 2013
    why cant you strap it. get the good straps. big long ratch ones
  5. mitrucker
    mitrucker Road Train Member
    5,140
    8,804
    Dec 15, 2010
    Lapeer, MI
    Freight is covering the e channel.
    Did you actually read the post?
  6. 201
    201 Road Train Member
    12,042
    24,575
    Apr 16, 2014
    high plains colorado
    Looks like another happy beer hauler. Not sure the issue, as I've hauled a lot of beer to the rail,( and picked up beer loads that came in off the rail), and they never moved with an air bag with NO load bars. I'd have put the load bar on the nearest slot to the last pallets, maybe 2 empty pallets on end and a bar and go.
    And for the record, I'm from Milwaukee,( and I ought to know) and Miller shipped a lot of beer, trust me.
    Judge, bryan21384 and JC1971 Thank this.
  7. kylefitzy
    kylefitzy Road Train Member
    4,596
    18,980
    Aug 12, 2007
    Kansas city,Mo
    Why not just use the first available e track slot. Is most van freight not loaded agains one wall? I’m not a box jockey.
    RubyEagle and Malt Ball Cult Thank this.
  8. mitrucker
    5,140
    8,804
    Dec 15, 2010
    Lapeer, MI
    Former box jockey turned tanker yanker here.
    When you use straps in a box, they need to put tension on the load to keep in from moving. They work best when used in a “V” shape.
    And no, it needs to be loaded evenly throughout.
  9. Dockbumper
    Dockbumper Road Train Member
    3,778
    9,860
    Apr 29, 2020
    That load probably has the pallets against both walls with air bags down the middle. I've dealt with it before. E tracks are blocked. I would usually put a load bar about a foot back from the load, then put a ratchet strap I the next available e channel and suck the trailer sides right against the load bar. Worked well. A dry van has too much flex in the walls for load bars alone. I have always used the combination of the two.
    201, Magoo1968, Malt Ball Cult and 3 others Thank this.
  10. Capacity
    Capacity Road Train Member
    1,499
    3,116
    Jul 28, 2019
    Neenah Wi
    Cut the sewn on end off your e track straps and make it 2 pieces , melt the cut end so it dosent fray , hook your snaps BEFORE they set the pallet in place.
    I wonder how long a airbag takes to decompose in the land fill.
  11. Dockbumper
    3,778
    9,860
    Apr 29, 2020
    Nobody ever let me on the dock for a beer load
