Load Lock Troubles
Discussion in 'Refrigerated Trucking Forum' started by Frank Speak, Jul 26, 2017.
  1. Frank Speak
    Frank Speak Road Train Member
    4,478
    13,665
    May 3, 2016
    I used to never have issues, but lately it seems like the top bar falls at some point in transit. And, my last load even the bottom one fell and I always put it low against the base plate where there's no flex.
    I prefer the ratchet kind, but we use the cheaper, spread and lever lock kind so those are what I'm dealing with. Any tips from others using those type?
  3. gokiddogo
    gokiddogo Road Train Member
    8,786
    14,766
    Mar 5, 2012
    Ontario Canada
    The cheaper ones you need 2 of them to use 1 of them effectively, and mildly effective at that.
    Put first one on as tight as you can get it. Put 2nd one on directly above or below first one, stretch it to the maximum and then tighten it. The first one you put on will come loose if you do it right. Repeat it as many times as you dare. No matter what you do with this style of load bard, they will share the load equally if they are too close together, and one of them will almost always fall to the floor. Be careful, this is a good way to put rips in your trailer where the scuff board meets the kemlite at the bottom, over time. E-track prevents this, but does add weight to tare weight of the trailer.
    Frank Speak Thanks this.
  4. sdaniel
    sdaniel Road Train Member
    5,511
    4,420
    Sep 7, 2011
    Pelham N.C.
    Liked using a load lock and a strap together .
  5. gokiddogo
    8,786
    14,766
    Mar 5, 2012
    Ontario Canada
    If E-track is in the trailer that works well also. If there is E-track the big square bar works best.
    Another tip. If you keep the same trailer or are responsible for your own load bars, unload them every time before you back into the dock and just put them on the ground or against the wall. Forklift drivers like to run them over and replacing them due to other people's stupidity is not my idea of a wise expense.
    NavigatorWife Thanks this.
  6. Allow Me.
    10,642
    12,099
    May 28, 2009
    Rancho Mirage, Ca.
    try putting load lock floor to ceiling instead of wall to wall. Might work better for ya'.
  7. pattyj
    pattyj Road Train Member
    22,474
    20,138
    Jul 19, 2008
    Sioux City,ia
    I've never tried that but good idea.
  8. gokiddogo
    8,786
    14,766
    Mar 5, 2012
    Ontario Canada
    Should only use vertical load bar when you have a single pallet and absolutely have to. To get it tight enough you can easily damage the trailer roof.
    I don't think the single motion lock, cheaper load bars will even reach from floor to ceiling. The jack bars will.
  9. magoo68
    magoo68 Road Train Member
    3,393
    5,385
    Jun 11, 2011
    st malo mb canada
    Just make sure you don't push up air chute or you may get a claim ... grab a few chunks of 4x4 to put under bar if it's too short
  10. gpf87
    gpf87 Heavy Load Member
    765
    881
    Feb 2, 2017
    What works for me is to put the load lock pretty tight but at a slight angle , then pull down on it to make it level
    Repeat with the lower one and step on it with your body weight
    Never had a load lock fall en-route
    12 ga, MachoCyclone, Big_D409 and 4 others Thank this.
  11. supersnackbar
    18,596
    44,699
    Aug 19, 2007
    Your Town, USA
    When I was pulling a reefer, I would only use 1. It seemed that if I put in a 2nd, it would spread the wall just enough to make both fall enroute. I too would put it tight at an angle then push it up level, and as tight to the freight as I could without damaging the product. The one thing I did discover, some of the older bars the company handed out had the rubber feet starting to harden from age, so they didn't grip the wall very good, especially on those -10 loads when the walls frosted over.
