load limits / capacity on flatbed trailers?
Discussion in 'Flatbed Trucking Forum' started by alfio, Apr 2, 2024.
  1. alfio
    alfio Light Load Member
    63
    33
    Jun 2, 2021
    Hello all,
    I'm wanting to use an older flatbed trailer to use as a bridge for crossing a small creek that goes through our place. The span is 22 ft or so max which means I can prob cut the trailer in half and have a nice wide crossing.
    I want to get the heaviest duty frame / deck combo I can afford. Ideally, once I place, I will be able to drive a loaded tandem dump over to the other side to spread gravel/continue building the driveway up (that is approx 45K lbs when loaded). Those of you familiar with flatbed loads, is this a reasonable expectation or crazy town to try something like this?
    There's not a lot in the budget for this so I want to be careful in what I'm buying. Any advice? Thanks all
    TX2Day Thanks this.
  3. xsetra
    xsetra Road Train Member
    5,092
    6,939
    Aug 21, 2011
    I've sold a couple flatbed for bridges.
    One, I transported a mobile home over.
    No problem with the main beams, not sure about the your deck carrying the weight.
    How close are the cross members? What kind of deck? Wood, aluminum, steel?
    TX2Day Thanks this.
  4. alfio
    63
    33
    Jun 2, 2021
    All good questions. I'm seeing that the steel trailers with wooden decking are the most affordable. I'm looking around and seeing different options, not sure what configuration would give me the best options as far as the decking.
    TX2Day Thanks this.
  5. REO6205
    REO6205 Road Train Member
    13,172
    60,483
    Feb 15, 2014
    California.
    Ever think about an old railroad flat-car? Longer, wider, built heavier. We use them for bridges in the woods. They'll last.
    shanman, Vampire, W923 and 2 others Thank this.
  6. Willy Wonty
    Willy Wonty Light Load Member
    105
    432
    Feb 3, 2020
    PNW, almost Canada
    That's a good idea!
    alfio Thanks this.
  7. W923
    W923 Road Train Member
    1,292
    3,923
    Feb 28, 2022
    Just for reference 2” thick oak decking with supports 2’ on center will hold around 12k pounds on a 12 inch wide tire at around 15-18k it gets a little sketchy. Not a scientific study but seems pretty reliable from what happens to the floor of my rgn.
    The main beam of the trailer will be fine especially considering you cut the span down considerably. Cross members idk just depends on what they are. Generally I wouldn’t expect a problem.
    I like the rail car idea but it would probably be much cheaper and easier to use the flatbed trailer
    alfio and Vampire Thank this.
  8. alfio
    63
    33
    Jun 2, 2021
    Thought about it but I don't have anything heavy duty enough to bring it here or move it around when it gets here. Also they are $! At least the ones I can see that are reasonably close. Good option though.
    A
    REO6205 Thanks this.
  9. alfio
    63
    33
    Jun 2, 2021
    That's super helpful. I'm thinking that if I go this route, I can split the trailer in half (length wise), cut off the supports on the two "middle" sections and will be able to set it up so that the two sections of main beams will be (roughly) at the track width of my dump truck so most of the weight will be over the strongest part of the trailer sections.
    A
  10. LTLTRUCKDRIVER
    LTLTRUCKDRIVER Light Load Member
    157
    286
    Jun 3, 2019
    A fence company here in South Texas uses old container chassis to make farm / ranch bridges don't know what they use for decking, the owner of company said they were cheaper than old flatbeds.
    W923 Thanks this.
  11. W923
    1,292
    3,923
    Feb 28, 2022
    Just make sure there’s enough support from the ground at the ends so it doesn’t sluff off and dump your bridge in the creek
    Ruthless Thanks this.
