Load Air guage
Discussion in 'Peterbilt Forum' started by Hogleg, Dec 6, 2016.
  1. Hogleg
    Hogleg Medium Load Member
    311
    258
    Nov 20, 2016
    Salem, Illinois
    I am wanting to put an in cab load gauge on the tandems air bags. Is there a electronic air gauge available or do I have to run an air line all the way from the tandems into the cab? This is a 205 WB truck so that is a lot of air line! I guess I could mount a load air gauge somewhere near the pogo stick external. We haul grain and a load gauge is helpful at times to know if we are close to max weight away from the scales.
    John
  3. 201
    201 Road Train Member
    12,044
    24,581
    Apr 16, 2014
    high plains colorado
    Line is cheap, better than a ticket. You have to go right to the leveling valve, or to an air bag, a T fitting and a regular gauge. It was the 1st thing I put on my trucks. 63 lbs. in the suspension was about 34,000. They were never too exact, but gave you an idea if you should, or should not go over a scale. As a side note, I don't ever remember seeing a grain box at a state weigh station, unless they dragged them in from a side road.:eek:
  4. Hogleg
    311
    258
    Nov 20, 2016
    Salem, Illinois
    DOT guys set up scales at the last turn into the grain depot on the river, right across from the police station.
  5. Gunner75
    Gunner75 Road Train Member
    5,701
    9,073
    Mar 17, 2014
    Jackson Center Ohio
    I helped my father in law install one directly on the air bag. He drilled into the top plate tapped it, installed a quick connect fitting, ran the airline to the dash, cut a hole in the dash and installed the gauge on the panel next to the radio. It was an 100psi gauge. At 65psi it was around 34k on the tandems. says he zeroed it without a trailer hooked. With the trailer hooked it showed 11psi.
  6. baha
    baha Road Train Member
    4,137
    2,835
    Jul 25, 2013
    ga
    If you have the air dump switch on your dash you have a place to T in the gauge, if not now is a good time to replace air ride valve with one with a dump type an run the air line thru firewall?
    KB3MMX, Oxbow, Hogleg and 1 other person Thank this.
  7. beemergary
    beemergary Light Load Member
    229
    112
    Apr 11, 2014
    My son n law and dad farm in southern Mi. by Ohio border. The DOT keeps a good eye on them farmers. Lots of safety issues. They stopped the boy just the other day. He was empty but was asked how much you haulin? He had a weight ticket in his pocket. Close but not over. His truck is stretched with lift axle and two big gravity boxes.
  8. AModelCat
    154,243
    They aren't too hard to install. Just tee into the line anywhere on the bag side of the leveling valve and run the airline up inside the dash. If you have a blank hole in the dash and are somewhat mechanically inclined, you should be able to install it nicely in an hour or 2.
  9. witch_hazel
    witch_hazel Bobtail Member
    47
    85
    Nov 27, 2016
    don't they have digital gauges now they read in pounds?
  10. AModelCat
    154,243
    I was just looking into that the other day. There is a company that makes a gauge that reads in lbs once you calibrate it.
  11. wore out
    wore out Numbered Classic
    15,319
    184,958
    Jun 5, 2013
    CHASIN THE DEVIL'S HERD
    We run ours in cab. Always start in the same spot of the slope on the front when it gets to 50 pull up to the back. Same procedure but 60. Puts me at 80 K and legal on all axles never having to get out but to roll my rag. Don't count on my numbers though each truck is a little different
    Oxbow Thanks this.
