Livestock question
Discussion in 'Ask An Owner Operator' started by zinita17601, Feb 21, 2016.
  1. zinita17601
    zinita17601 Road Train Member
    1,317
    1,603
    Aug 19, 2010
    lancaster pa
    Can anybody tell me how many lambs or goats can i haul on average on a livestock trailer?
    If the average weight per animal is 100 lbs and i can haul 40klbs does that mean i can haul 400?will they fit?sorry if this question is too stupid
  3. Al. Roper
    Al. Roper Road Train Member
    1,511
    10,720
    Apr 21, 2013
    Bakersville NC
    You talking about a pot, right?
    @wore out ,@KAK
    TheJrodTest, KAK and Straight Stacks Thank this.
  4. zinita17601
    1,317
    1,603
    Aug 19, 2010
    lancaster pa
    Yes
    Al. Roper Thanks this.
  5. Al. Roper
    1,511
    10,720
    Apr 21, 2013
    Bakersville NC
    I would think 400 or so should fit on at least a 48x102. If it has a split deck nose compartment, and a dog house. I've watched guys load 130-140 300+ pound calves on one, so they should fit.
  6. zinita17601
    1,317
    1,603
    Aug 19, 2010
    lancaster pa
    Im not really familiar with the terminology but thanks for ur help
  7. Al. Roper
    1,511
    10,720
    Apr 21, 2013
    Bakersville NC
    No problem.
  8. Cottonmouth85
    Cottonmouth85 Bad Influence
    2,637
    8,700
    May 3, 2012
    Floresville, Tx
    That's alot of cabrito, Hombre
  9. Long FLD
    Long FLD Road Train Member
    11,366
    45,787
    Mar 4, 2015
    If you want to haul sheep and goats and have any shot at making money you're going to need a 4 deck trailer. There's no way you'll get a decent load on a regular cattle trailer and not have problems
    KAK, wore out, d o g and 1 other person Thank this.
  10. zinita17601
    1,317
    1,603
    Aug 19, 2010
    lancaster pa
    What kind of problems?
  11. d o g
    d o g Trucker Forum STAFF Staff Member
    24,449
    53,299
    Sep 20, 2010
    Texas
    He's referring to problems of being loaded too tightly. Keep in mind that the smaller and shorter the animal, the more floor space that is required to get the same amount of weight as you would get with larger animals.
    For example, high-yielding packer bulls or really gaunt utility cows will maximize your loaded weight for the same amount of floor space because they're taller and have more muscle throughout that frame height - muscle is heavier. As your stock gets smaller and smaller, you lose that muscle weight from the additional frame height and maturity of the animals in your load, but the floor space required for the smaller ones doesn't decline at an equal rate.
    Basically, you aren't using as much of your trailers volume capacity because of all the wasted space between decks when loading it with shorter-framed animals. You'll be using a lot of the floor space, you'll just have a lot of air above them. That's why they use triples for really light calves like 2-weights, and they use triples and four-decks for hogs, sheep and goats, etc. Those additional decks allow you to utilize more of your trailer's volume instead of just using floor space.
    It might just involve trial-and-error on your first load. But, if you're familiar with your trailer, once you get your bottom nose loaded and take a few minutes to do the math, you'll know how many more you can load to finish out.
    KAK, Al. Roper, zinita17601 and 2 others Thank this.
  12. HopperHauler
    HopperHauler Trucker Forum STAFF Staff Member
    514
    1,684
    Jan 22, 2011
    North Dakota
    I have a couple buddies who used to haul pygmy goats from TX up to Paterson, NJ. I remember them saying they would get 700+ on the trailer. I think they pulled 53×102 sheep pots with the 3-4-3 deck setup.
    d o g Thanks this.
