Liquid Propane Haulers: Tips? Advice?
Discussion in 'Hazmat Trucking Forum' started by OhNoTerry, Dec 15, 2023.
  1. OhNoTerry
    OhNoTerry Medium Load Member
    309
    470
    May 22, 2021
    Starting a new venture into bulk propane hauling. Any tips and tricks you've learned along the way from hauling, loading and unloading this type of commodity?
    minnisnowman and austinmike Thank this.
  3. lester
    2,914
    7,842
    Jan 2, 2012
    NW, Iowa
    there is no such thing as an empty line.. at least with anhydrous.
    Friend, austinmike and OhNoTerry Thank this.
  4. lual
    lual Road Train Member
    4,389
    7,900
    Oct 22, 2020
    SW Georgia
  5. haz-matguru
    haz-matguru Road Train Member
    2,866
    4,340
    Feb 18, 2012
    Be patient, your day can change because of a refinery issue, trailer loading issue. And other things that can come out out the blue.
    Also close the vapor line on the last 5% of loading. That way your trailer will have higher pressure than where your delivering.
  6. aussiejosh
    aussiejosh Road Train Member
    4,709
    5,408
    Aug 28, 2009
    Airlie Beach QLd
    Yep stay away for any naked flames or other ignition sources and you'll do great mate.
    austinmike Thanks this.
  7. Cat sdp
    Cat sdp . .
    20,819
    71,604
    Apr 8, 2012
    Orion's Belt
    Freeze burns suck……..
  8. 201
    201 Road Train Member
    12,052
    24,606
    Apr 16, 2014
    high plains colorado
    There was a time when drivers of certain commodities, particularly hazardous ones, got a premium for doing those jobs. Today, I don't think it pays anymore than diapers in a van trailer. With all the dangers on the road today, you might be better with the diapers. In my millions of miles in a truck,, I hauled ONE load of gasoline. The company also did LP and Anhydrous( nastiest stuff) It clearly wasn't for me. Considering how much propane travels our roads, especially now, I think crashes are very rare, and you'll do fine.
    OhNoTerry and Cat sdp Thank this.
  9. Cat sdp
    Cat sdp . .
    20,819
    71,604
    Apr 8, 2012
    Orion's Belt
    Also we used to sit in the tractor while pumping the load off . So you could shut the truck off in the event of a leak . Now most companies , receivers make you stand out by the manifold of the trailer while the truck is pumping away. So you can close the internal valve I guess.
    sorry but that’s desk jockey thinking and is wrong.At least if your using a truck to pump off.
  10. RockinChair
    RockinChair Road Train Member
    4,928
    12,277
    Feb 19, 2012
    CC, TX
    It's so that you can activate the emergency shutoff on the trailer, which closes all of the internals and simultaneously stops the flow of liquid and vapor.
  11. Cat sdp
    Cat sdp . .
    20,819
    71,604
    Apr 8, 2012
    Orion's Belt
    And the trucks still running at high idle and if the propane gets in the air cleaner is all over…….
    If you using the truck to unload a trailer you belong in the cab……
