how high show the liner set from the block with out the spacer plate installed kinda pain to messure with plate on i know i need 3 to 6 thous just a rough idea might help me out here
liner height 6nz c15
Discussion in 'Trucks [ Eighteen Wheelers ]' started by little cat 500, Sep 2, 2011.
I just went through this myself, and you probably don't want to hear this, but the only accurate way to measure it is with a new spacer gasket and the spacer on, clamped down with short bolts in place of the head bolts with steel washers on top of fiber washer (available at Cat). The best I understand it, this is to make sure that the liners are pushed down into the block like they will be with the head on, and to make up for any slight imperfections in the deck surface of the block. It is a pain, but it's the only sure-fire way to do it. You're going to need a new spacer gasket anyway, why not just go ahead and measure it the right way?
Having said all that-the spacer is .338" thick and the spacer gasket is about .007" thick once it's mashed down. So I think the numbers you're looking for are roughly .347 to .352. You really aren't going to be able to measure it accurately like that though. -
ok head gasket blew between 3and4 4and 5 5and 6 with spacer bolted down all liners are pretty much even with the top of spacer plate is this normal for all the liners to be low at the same time ? now what if i milled the spacer down a couple thous truck burns no oil and no blow by
That's what happened to me, mine blew between five and six, all of my liners were getting a little low but were within about .002 of each other. Cat makes a thinner spacer plate that's .335 thick, my machine shop told me I was better off buying it than hoping they could get my old one milled down right. I can get you the part# if you need it.
The thinner spacer plate is 138-9381 this plate is .003" thinner than the standard plate. The only way you can use this plate is if all the liners are within .002" adjacent to each other and the overall measurements from one end of the block to the other end, the projection is less than .003" with the standard plate. If you have one cylinder at .0035 and the two cylinders adjacent are .0025 when you install the thinner plate the measurements would raise the liner projection to .0065 with the two adjacent cylinders being .0055. You'd be taking a risk of cracking the liner flange on the .0065 cylinder at a later time even though it's within the .002" spec of the liners next to it.
The reason you're taking this risk is the liner is above the max of .006". To have a high liner projection means that the head is exerting more downward pressure on the flange/linner this shears the flange off the top of the liner -
ok good news i think took the spacer and gasket back off and i come up with .350 on the liner flange now if the spacer is .338 and gasket is .007 that gives me.345 so that should be .005 on the liner height or am i looking at it wrong again
You have a major problem with this. Each liner is supposed to be measured in 4 locations around the circumference of the liner while it is torqued down with the spacer plate and gasket. You aren't taking into account the difference from one liner to the next to it and so on. Have you inspected the block deck surface under each liner flange? Do any of them show signs of fretting? Can you still see the original machined surface and machine markings of the block deck where the liners sit? If the answer is no to the first and last questions, and yes to the second question, you're asking for another head gasket failure. Without taking the liner projections of each cylinder and averaging them and comparing them from one to the next and the overall difference for all the cylinders, you can have a head gasket failurejosh.c Thanks this. -
i did check them in 4 spots around the liner .350 to like .351 is the ave for all 6 holes block surface appares to look fine i didn't move the liner's to look under the flange surface under the liner flange do you mean pull the liner up to look ? i did have 4 head bolts in the back of the motor that were loose like maybe 100 pound or so of tork with a straight edge there is no dif in liner height
You have to pull the liners to check the mill marks. If you pull them you have to replace the 3 o-rings and the seal. -
i did do it the way i was told with the spacer plate bolted down and they seam to be all low that way so i did it with out the spacer plate and with a known measurement of the spacer and spacer gasket i end up on the good side of the liner height is all im saying here just trying to get a feel for why can't it be a known height with out the spacer that don't hold the liner down i just thought that if you pull the liner that's in question why put it back in im just asking at this point head is still on the floor and i never rebuilt a deisel im still learning
