Whats a good lightweight trailer? Ive seen billboard somewhere advertising 7xxx lb flatbed trailer and that would be nice setuo for me.
Lightweight flatbed trailer
Discussion in 'Flatbed Trucking Forum' started by mitmaks, Aug 11, 2017.
Page 1 of 3
passingthru69 Thanks this.
Fontaine make a nice one. I had a Ravens that weighed in at 8700.
My Benson flat is all aluminum and weighs 9900 lbs with a single tarp box. I've had close to 60K on it several times. That load was concentrated in the middle 10-15 ft. Those loads are the only ones that can actually take the arch out. 45K of steel dead center doesn't do much to make it flat.
Also have a 3 axle all aluminum Reitnour Bug Bubba flat that I've had 86K on going down the road. Have also used it for a short move in a plant for a single 117K piece. Both of those had the load distributed across about 15FT. The Reitnour is around 13K empty.
Like @ChaoSS said though both of these have some pretty beefy frames under them which does add to the empty weight.
I've seen some of the contained with light decks and smaller frames that look pretty light. Only downside I've seen on them is lack of support near the edges of the deck. They were good for steel loads though where most of the weight will be focused near the middle right over the frame rails. Wouldn't recommend loading anything that has to rest only on the edges of the deck though.snowman_w900, cke and DDlighttruck Thank this. -
Razororange Thanks this.
Something like that would be great for coils, brick, or asphalt shingles.
Page 1 of 3
