Lighting problems
Discussion in 'Peterbilt Forum' started by Telefranco, Jul 31, 2020.
  1. Telefranco
    Telefranco Bobtail Member
    2016 Pete 579 363688
    I'll try to make this as short as possible....
    When switched to parking lights - only clearance lights are constantly on. No side markers or front parking lights. Turn signals still work
    When switched to headlamp - all lights work as they should.
    Now the twist.
    This is affecting both the tractor and trailer connected or disconnected. I replaced the switch....no fix. When checking the pigtail....
    Switched to parking lamps - white - grounded
    Brown - grounded black - powered
    Switched to headlamps - white - grounded
    Brown- powered black- powered
    I recently connected to another companies trailers which are older model than my company's and when connected all my lights worked exactly as they should in all positions but only when connected to those trailers.
    All lights are LED except for front marker lights.
    Also to contradict info above, when switched to parking lights my tractor taillights I noticed do actually light up constant but extremely dim.
  3. Telefranco
    This is picture of parking lights switched on.
  4. Goodysnap
    Goodysnap Road Train Member
    3,694
    8,948
    Jul 12, 2017
    Go through the inside and outside fuse boxes carefully. Make sure all fuse and relay locations on the label have good fuses installed and in the correct location. Also check the relays. The fuse box has a white outline around the relay location, some of the smaller relays can be accidentally installed outside of the correct position.
    Missing fuses are common. From there a wiring schematic and some troubleshooting will be needed. Inspect chassis harness wiring for rubs and shorts below the cab behind the LH fender/step and chassis node module.
    QUALITYTRUCK Thanks this.
  5. Telefranco
    Checked fuses and relays, forgot to mention that was my first step but will check harness and wiring especially in that location mentioned in the morning and will update then. Ty for quick reply
  6. Roberts450
    Roberts450 Road Train Member
    2,237
    3,635
    Feb 6, 2016
    The rear tail light being on very dim is just an indication that the key is on or that the door is open. Probably only lighting up a couple of the LED’s in the taillights, seems to be standard on pete’s since at least 2012.
  7. Goodysnap
    3,694
    8,948
    Jul 12, 2017
    The tailight glow is residual voltage from the chassis node. Its not enough to cause any kind of battery drain and will only light LED tailights. I do have a fix for this if anyone is interested I can share on Monday.
  8. Goodysnap
    3,694
    8,948
    Jul 12, 2017
    Rear taillight glow with truck off fix.
    Install taillight jumper harness part# A92-6004-005
    Paccar is proud of this one- 250 clams to a walk in customer.
  9. w9l
    w9l Medium Load Member
    316
    513
    Oct 12, 2013
    Boss has a 2012 389 I drove for a month last year. It gave me all kinds of lighting problems . When sitting running with park lights on headlights would go on spells of flashing strobe like emergency vehicle. Headlights would go dim going down the road and finally quit. Markers were doing strange things too. Took it to dealer and 2 other shops and finally replace body control module? About 1400bucks in parts. Problem solved.
  10. QUALITYTRUCK
    1,801
    1,762
    Jun 14, 2009
    romulus,mi
    Chassis node under truck on driver frame rail. Nothing could damage a module down there right??
    spsauerland Thanks this.
  11. w9l
    316
    513
    Oct 12, 2013
    That is where it was located alright. Pretty well protected from physical abuse. Maybe it was mental abuse that got it, but I think some sort of electrical spike took it out. The driver before me was running it without a clutch brake so he was leaving it parked in gear. I went to pick it up and from the ground slapped the shift boot and thought it was in neutral. Hit the key and it just clicked. I hit it a second time and same thing. Then I woke up and realized what going on. From that time forward until module was changed it had an abundance of mysterious lighting gremlins and got progressively worse over a 10 day period until headlights same as went out about 4am. Glad I was empty.
