Lightest hopper bottoms?
Discussion in 'Experienced Truckers' Advice' started by T-800, Oct 19, 2014.
  1. T-800
    T-800 Light Load Member
    98
    45
    Sep 20, 2014
    Frankfort, IN
    We are about to purchase a hooper trailer and are tryin to figure out the lightest combo. Would you want a short trailer tall sides or all short, ect? We will be hauling commercially so weight is everything. We know where going to buy a timpte or wilson, we're looking at some of the late 90s early 2000s. Any experience?
  3. MJ1657
    MJ1657 Road Train Member
    7,521
    50,150
    Jan 28, 2012
    Isanti, MN
    We run Wilson's. We have a '10 42 foot with the taller sides, aluminum front and rear frame. I can't remember how many inch it is. We have a '94 40 foot with short sides steel front and rear frame. The '94 weighs 800 pounds more then the '10.
    Just something to think about.
  4. T-800
    98
    45
    Sep 20, 2014
    Frankfort, IN
    Huh. I knew alum wheels took off quite a bit. But I don't know if he wants to get an alum frame. But that was good info. What's the dry weight of the 94?
  5. MJ1657
    7,521
    50,150
    Jan 28, 2012
    Isanti, MN
    I do not know that I just know the difference between the two when they are behind my truck. I wouldn't be afraid of aluminum frames. We pull out of the field some and as long as you take it slow they hold up just fine.
  6. T-800
    98
    45
    Sep 20, 2014
    Frankfort, IN
    Any brand preference? What length and options would you suggest? We're getting the standard sides so our neighbor can dump in it too
  7. magoo68
    magoo68 Road Train Member
    3,393
    5,385
    Jun 11, 2011
    st malo mb canada
    Light commodities require tall and heavy your fine with short sides weight wise there was 4 or 500 lbs difference if I remember correctly ps a short side was better on fuel with a flat top bunk
  8. T-800
    98
    45
    Sep 20, 2014
    Frankfort, IN
    And we will be hauling dent corn, soybeans, wheat, and I think that's it. What options would you suggest to get lighter? Do ag hoppers and stuff like that shave weight? Any other options we should look for?
  9. T-800
    98
    45
    Sep 20, 2014
    Frankfort, IN
    Ok I read over that and it didn't sound right. What I'm asking is what options make them heavier and which ones make them lighter
  10. MJ1657
    7,521
    50,150
    Jan 28, 2012
    Isanti, MN
    Aluminum front and rear frames like I talked about earlier is probably your biggest weight savings. We switched ours to super singles and saved 400 pounds.
  11. pcfreak
    pcfreak Heavy Load Member
    835
    385
    Apr 22, 2007
    Alberta, Canada
    Check out Dakota Trailers. Based out of Yankton, SD. All aluminum hoppers with very large unloading slides. Ran a set of super b units where I could unload two hoppers into one unloading auger if I had them sitting just right.
