light weight tarps
Discussion in 'Flatbed Trucking Forum' started by foresaken, Dec 21, 2011.
  1. foresaken
    foresaken Light Load Member
    62
    12
    Oct 19, 2011
    springfield, mo
    who has the best light weight tarps. I currently carry 2 lumber tarps and 2 steal tarps. No 46 inch box to store them. Strap them where ever I can. Plus I am 56 and getting real tiered of the lifting.
    So who has the best light weight tarps?:biggrin_25523: Prime trash workin his a@( off tarpping!
    SHC and lowjo Thank this.
  3. schmud0811
    schmud0811 Medium Load Member
    379
    283
    Jun 2, 2010
    Phoenix,AZ
    from my experience and I have been buying alot of tarps....Do not use all 14oz vinal!!! they will tear looking at them cross eyed. now 18 oz on top 14 oz on the sides will work.
    One of the guys on here uses tarps with a 4 foot drop and attachable skirts to cover the other 4 ft if you need to do a lumber load.
    Lepton1 and HopeOverMope Thank this.
  4. Mommas_money_maker
    Mommas_money_maker Road Train Member
    1,122
    765
    Oct 2, 2011
    North Carolina
    What about the ones with vinyl tops and the lightweight "parachute material' sides? I have been looking into some new lightweight sets myself and wondering if anyone has experience with these.
  5. blanco
    blanco Road Train Member
    1,221
    296
    Nov 20, 2009
    Gwinnett County, GA
    some other guy on here said you can use the billboard canvas and they are cheap and strong too.
  6. fortycalglock
    fortycalglock Road Train Member
    6,150
    6,581
    Jun 25, 2011
    Tourist Town, FL
    If all you haul is boxy stuff or lumber, the lightweight sides will work great. If you haul anything that is an odd shape, be prepared to have them fixed after that load. I had two sets on trucks, and have gone back to 18oz tarps, but split them up into three tarps instead of two. It makes them lighter and you don't always need a 26' long 8 foot drop.
    Lepton1 Thanks this.
  7. Espressolane
    16,975
    102,334
    If memory serves me, on e-bay some people had been selling pallets of the vinyl billboard covers for cheap, like $35.00 each or a pallet of them for less than $400.00.
    They are the same material as a light weight tarps. 10 or 14 Oz, depends on who made it.
    I have seen these being used. No D rings or grommets on them. from the ones I have seen, they do have a draw cord on the open edge. Turned inside out they have no printing on them.
    Broke Down 69 Thanks this.
  8. foresaken
    62
    12
    Oct 19, 2011
    springfield, mo
    haul all diffrent types of cargo, pipe, sheet metal, Cat parts, rolls of steel and aluminum:biggrin_25510:
  9. Oscar the KW
    Oscar the KW Going Tarpless
    12,246
    28,114
    May 19, 2011
    I have tarps with the parachute sides and the only loads I tarp are usually odd shaped machinery and stuff like that. I haven't had any problems with mine. But I always use more bungees than is necessary to keep them from flopping in the wind.
    Mommas_money_maker Thanks this.
  10. Markvfl
    Markvfl Road Train Member
    1,103
    338
    Nov 29, 2007
    Apopka, FL
    Lightweight tarps work fine if you pad the load before throwing them. Go to your local carpet sales and installation center and ask them to save you some larger room tear outs. They throw them away so most of the time they will be happy to give them to you. Cut them into 18 to 24 inch squares and carry at least 25 or 30 of them with you. Throw a couple rolls of duct tape in the box. Before you tarp the load look at it and identify the pointy parts. Duct tape the carpet squares covering them so that they don't get knocked off when you throw the tarp. Your tarps will last many times longer with the padding then without it.
  11. Mommas_money_maker
    1,122
    765
    Oct 2, 2011
    North Carolina
    I always use padding but thanks for the tips anyway and good to hear about the lightweights with parachute material sides. I was already looking into the 3 piece as I dont tarp a whole lot but always seem to get a partial on that needs one and not a full size one.
