Light weight rear gear option? RPM/Speed calculator?
Discussion in 'Kenworth Forum' started by Green461, Apr 8, 2019.
  1. Green461
    Green461 Light Load Member
    147
    91
    Mar 22, 2019
    Southern WI
    I've found some of these calculators online but dont have any info in front of me that I need, tire height? revolutions? Clicked on Eatons and it tries to open some some file my pc doesnt recognize.
    Current setup:
    01 KW T800 Detroit 12.7 430/500hp 1650 lbs/tq ....Trans: RTLO16913AP......Rear - 3.90's Tires- 11r22.5
    Weight of the truck and load combined will never be over 30k lbs. Region - Everywhere in the continental states OTR. No one place more than the other really.
    I am not driving the truck now, working on it, but I think 70mph was around 1600rpms in 13th gear.
    I'd like to do that in 11th (direct) or maybe even drop it to 1500rpms @ 70mph.
    I was thinking 3.50's but cant find a chart/calculator to see where it gets me. After reading some posts on here 3.36 might be better? 3.08's ?
    Anyone have a chart? RPM/speed/rear gear, or a Calculator?
  3. gokiddogo
    gokiddogo Road Train Member
    8,786
    14,766
    Mar 5, 2012
    Ontario Canada
    1600÷3.90×3.08=1263rpm In 13 @ 70mph
    At 2.64 you'd be at 1083 rpm at 70 in 13. If you think each full gear is about 400 rpm you'd be at roughly 1483 in 11 at 70mph with 2.64. Give or take.
    KB3MMX Thanks this.
  4. Green461
    147
    91
    Mar 22, 2019
    Southern WI
    Thanks. That equation will work for direct gear 11th 1:1 but when you go into overdrive the input to the rear end no longer matches the engine RPM. I dont think each gear is a full 400rpm? I dont want to guess. Im assuming if 1000rpms of the driveshaft would be 860rpms at the engine in 12th, and 730rpms in 13th. I was hoping for a calculator or chart so I dont have to figure out all the math myself. lol. I would think there is a chart somewhere that tells you the RPM at a given speed, and then the variations based on different rear gears.
    13th - .73
    12th - .86
    11th - 1.00
    KB3MMX Thanks this.
  5. gokiddogo
    8,786
    14,766
    Mar 5, 2012
    Ontario Canada
    Here is the website. I am writing this one from the computer, not the phone. It did not work in google chrome. It does work in internet explorer.
    Calculators
    click road speed calculator
    KB3MMX Thanks this.
  6. Green461
    147
    91
    Mar 22, 2019
    Southern WI
    It tries to open a .swf file and im not sure what that is so it doesnt work.
  7. 062
    062 Road Train Member
    6,143
    33,159
    Oct 20, 2013
  8. Green461
    147
    91
    Mar 22, 2019
    Southern WI
    I measure the 11r22.5 tires i have off truck and get 40" tall. On a few different ones. That totally contradicts any info on here that they should be 42" tall and LPs are 40" tall. So that kinda throws out any calculations i can do because not sure what tire height is.
    KB3MMX Thanks this.
  9. 062
    6,143
    33,159
    Oct 20, 2013
    A brand new 11r22 will be roughly 42. How much tread do you have left? You’ll can google the better brand tires and get specs off their website. I had some Chinese lp 24 that were 41.5 brand new.
    KB3MMX Thanks this.
  10. Green461
    147
    91
    Mar 22, 2019
    Southern WI
    I just used 41" tall, the variance should be small enough. I am making a chart with all gear ratios, rpm, and mph. taking forever but should do the trick. :)
  11. singlescrewshaker
    4,689
    40,504
    Dec 31, 2017
    Little Havana, FL
    When loaded light a detroit can spin high revs & still return good mileage. Mines 11r22.5, .73 od, & 4.10 rear. Empty I'm 26k lbs, turn about 1710rpm @ 70mph, & she gives about 11mpg. Ranging anywhere between 26-46k lbs gross with ramdom flatbed freight my last 5 ifta's have ranged from 8.5-9.2 mpg. With mileage like that there may not be much to gain from re-gearing..? Maybe run it the way she is for a while with the 3.90's & see if you think its worth it..
    Green461 Thanks this.
