light bar mounting
Discussion in 'Heavy Haul Trucking Forum' started by 7.3 cowboy, Nov 26, 2013.
  1. 7.3 cowboy
    7.3 cowboy Light Load Member
    210
    59
    Mar 4, 2013
    I am about to be hauling hay into Minnesota. I am wondering how you attach your light bars to your trucks. I have a peterbilt with fiberglass top so cant just magnet it. I am thinking about making a extension come off my headache rack.
  3. dogcatcher
    dogcatcher Heavy Load Member
    808
    2,674
    Apr 30, 2010
    tn
    I made a light bar out of tubing that attaches to my headache, then mounted the light to rubber makes a better shock absorber
  4. 7.3 cowboy
    210
    59
    Mar 4, 2013
    That's what I was thinking about doing
  5. Oscar the KW
    Oscar the KW Going Tarpless
    12,246
    28,114
    May 19, 2011
    I made two stands that bolt to the top of my headache rack, they also have my load lights bolted below the light bars.
  6. 15 over
    15 over Light Load Member
    84
    45
    Jul 1, 2013
    Mobile, Al
    This is how I mounted mine. I used a 3 foot piece of aluminum flat bar, 1/4'' thick and 2 inches wide. Cut it to fit the main braces on the head ache rack, welded some small trusses in under it. Then mounted my strobe in the middle and work lights on each side. It works real good and was not very expensive
  7. 7.3 cowboy
    210
    59
    Mar 4, 2013
    I like that 15 over
