Lift axles
Discussion in 'Experienced Truckers' Advice' started by Sportster2000, Aug 1, 2018.
  1. Sportster2000
    Sportster2000 Road Train Member
    1,480
    886
    Jan 5, 2008
    Indiana
    Are there any states that will not allow a truck with a lift axle? Thinking about adding one on a straight truck to put more of a load on it. Don't know where the truck will or will not go to including Canada.
    b61mack Thanks this.
  3. Accidental Trucker
    Accidental Trucker Road Train Member
    3,312
    7,223
    Jun 4, 2015
    Lift axles are not legal ahead of the drive axles in Alberta, last I checked.
  4. AModelCat
    154,240
    As far as I know you can have a lift axle installed on a truck in BC and Alberta but you cannot use it (ie must stay lifted). May want to double check that though and not just take my word on it.
  5. Long FLD
    Long FLD Road Train Member
    11,354
    45,708
    Mar 4, 2015
    A lift axle in Canada can’t have manual controls. For example if you had a lift axle it would have to be plumbed in so that when your bags on the drive axle hit a certain pressure it would automatically drop, which means you wouldn’t be able to run a steerable lift axle. If you have manual controls for it then it would need to be lifted once you got to the Canadian border.
  6. Sportster2000
    1,480
    886
    Jan 5, 2008
    Indiana
    This will give me a good point to start looking. Anyone know of any states that don't allow them?
  7. snowwy
    snowwy Road Train Member
    20,525
    13,261
    Jul 6, 2009
    I would imagine you can have drop axles in all the states. They don't care about axles. They only care about weight. I would imagine anyways.
    CA and AZ are 2 that come to mind. 34 and 80. Don't know about the east side.
    CA will do a heavy haul but I have noooo idea on the permits. I'm guessing not cheap either.
    I know NV isn't cheap.
  8. Jazz1
    Jazz1 Road Train Member
    2,373
    4,971
    May 7, 2012
    Thunder Bay On
    That's news to me. I lift or deploy axle manually depending on weight on board or road conditions. Amazingly I'm in Canada. Mind you I don't leave Ontario
  9. Long FLD
    11,354
    45,708
    Mar 4, 2015
    BC and AB ours have to be in the air when we cross the border. Lift axles on the trailers have to be automatic. I can’t speak for out east, I should’ve been more clear with my reply.
  10. Sportster2000
    1,480
    886
    Jan 5, 2008
    Indiana
    The weights hauled would all still be legal without permits. Company just doesn't want to wait the 8 months to have 3 trucks special ordered so they are thinking about buying some off a lot and adding the axles. Was even looking into putting a dead axle on it that does not have lift capability, they are harder to find than I thought that they would be.
