Lift Axles: Are They Worth the Money?
Discussion in 'Flatbed Trucking Forum' started by jldilley, Nov 5, 2014.
  1. jldilley
    jldilley Medium Load Member
    485
    406
    Oct 13, 2013
    Indianapolis, In
    Hello! Recently I purchased a brand new 53' Fontaine Revolution and I am interested in possibly putting a lift axle on the forward-most axle. It's my understanding that the decreased rolling resistance can greatly improve mpg. Before I take the plunge, I would appreciate any advice from those experienced with lift axles. Are the cost savings really there? Do they have added maintenence problems? Again, any help is appreciated.
  3. Flightline
    Flightline Road Train Member
    2,345
    1,165
    Oct 1, 2011
    Almost There
    Fuel economy gain and less tire wear.
    Well worth the money unless you forget to lower it crossing a scale with heavy load.
  4. Ruthless
    Ruthless Road Train Member
    8,786
    85,953
    Aug 28, 2010
    The City.
    ^ true, also consider the savings when you lift it going thru a toll
    281ric, Road Boss and jldilley Thank this.
  5. barroll
    barroll Road Train Member
    1,096
    544
    Nov 23, 2010
    Southwest Michigan
    I'll lift my rear with a chain running toll roads. There isn't much of a fuel economy gain (unlike the 1mpg gain some see going to single screw drives with a lift), but there is a reduction in tire wear, especially while backing, which gets a bit too easy with only one axle on the ground. I haven't found it worth another $3000 investment into my $10000 trailer, though. I'd definitely spec one new, though.
  6. jldilley
    485
    406
    Oct 13, 2013
    Indianapolis, In
    About how much weight would it add to my overall set up? Is it significant?
  7. Raezzor
    Raezzor Quis custodiet ipsos custodes?
    1,412
    1,186
    Aug 1, 2009
    Columbus, OH
    Wouldn't it be better to put the lift on the rear axle to reduce your turning radius?
  8. jldilley
    485
    406
    Oct 13, 2013
    Indianapolis, In
    I'd prefer to have it on the front, as my rear axle is a sliding axle.
  9. jldilley
    485
    406
    Oct 13, 2013
    Indianapolis, In
    And honestly, I prefer tandems as far back as possible for backing purposes. Having a tandem at the rear makes it so easy it almost feels like cheating lol.
  10. allan5oh
    allan5oh Road Train Member
    1,557
    556
    Jan 6, 2010
    Winnipeg, mb
    An axle lift is around 70 lbs. Hendrickson ubl system. He pronlem is with standard aant suspension on a flat you don't get enough lift, so they want an aanl suspension. That adds another 250 lbs or so.
    I like my lift axle, like others have said there's lots to gain.
    jldilley Thanks this.
  11. barroll
    1,096
    544
    Nov 23, 2010
    Southwest Michigan
    I've sat in an office waiting on a part while someone on the phone had the poor parts guy dig up the weights on every lift axle they could order. 300-500lbs heavier than stock was the norm if you want to keep your current load rating, but some ran 600-800lbs heavier.
