License Plate on front ?
Discussion in 'Expediter and Hot Shot Trucking Forum' started by Ryan S2016, Jan 21, 2017.
  1. Ryan S2016
    Ryan S2016 Medium Load Member
    450
    301
    Feb 11, 2016
    Western North Carolina
    I was reading a thread and saw a Youtube video where a driver said he puts is license plate on the front of his truck because with a trailer on the hook the DOT technically can't read your plate. He also mentioned that when you pull into a scale the scanners on the entrance ramp need to read them. I have never been stopped or questioned by DOT but I still don't know if it's something people do. States like NC TN SC and others only give one plate per vehicle so does that mean I have to get another one. And what happens when I don't have my trailer on there will be no plate there. Sure to get stopped then. Anyone heard about this?
    Thanks Guys
    RubyEagle Thanks this.
  3. LGarrison
    LGarrison Road Train Member
    1,246
    995
    May 19, 2011
    Sandpoint Idaho
    Call the DMV where you got your plates they will know
  4. striker
    striker Road Train Member
    6,026
    6,439
    Aug 8, 2009
    Denver, Co
    Colorado only issues one plate for a semi tractor, it goes on the front. Years back, I was stopped by a state trooper because I only had one plate, I pointed out that the state only issues one plate, not like cars, pickups and smaller CMVs that get two plates.
  5. Ryan S2016
    450
    301
    Feb 11, 2016
    That's the thing I run a small truck not a semi and I am only issued a single plate so I don't know if they would issue a second one for the front
  6. Ridgeline
    22,112
    113,286
    What kind of truck?
    What I was told was that they needed to see it but my state tells me if it isn't a semi, it goes on the back.
  7. clausland
    clausland Road Train Member
    1,933
    11,067
    Dec 5, 2014
    North Woods
    Depends on the State/Province.....In Quebec, they only issue one plate:
    Tractor- plate on front
    Straight truck- plate on back
    Pick-up- plate on back
  8. Ryan S2016
    450
    301
    Feb 11, 2016
    Ram 2500
  9. Ryan S2016
    450
    301
    Feb 11, 2016
    That's what I figured and confused why someone would say it should be on front. And is it true about the scanners at the scale entrance? Do they read the plates?
  10. clausland
    1,933
    11,067
    Dec 5, 2014
    North Woods
    Not sure about that one, but I'd think if you see it aimed at you coming in, it's likely reading the front plate...Will having no front plate displayed then get you pulled aside?....I don't know, but I'd speculate that if it's a class 8 tractor with no front plate displayed, it will.....A rig like yours, probably not, unless of course it's a slow day or they need to make quota....What does NC say about truck-trailer combos?.....Do they issue two plates for that type of operation?....
    Where you at in NC, out towards Asheville or up around Boone?...
  11. milehunter43
    milehunter43 Heavy Load Member
    732
    811
    Aug 23, 2015
    If I lived in a rear-tag-only state, I would place it on the rear of the pickup truck as your state intended. It's not a semi tractor.
