Levitating TV Mount
Here are the pictures: (https://drive.google.com/folderview?id=0BwYqgdLYz50HSU44RFlnakxqaUE&usp=sharing)
Howdy Ladies and Gentlemen of the of the road..!
Are you a company driver? Do you want to put a large
flat screen TV in your company truck, but don't know
how you're going to mount it without drilling holes?
Here's a possible solution I thought up. It works
great for me and may do you well for you too!
I have a 20xx Freightliner Cascadia with a 29in
display in it. Here's what I did to mount it. All of
this may work for you OR none of it may work for
you. I just wanted to get ideas circulating. The
things I used some in various shapes and sizes so
figure out what is best for your situation before
you buy. I tried a million variations before I
settled on this solution.
1.I bought these heavy duty drywall mount hooks from
Walmart. They have an orange grip on them.
2.I got two single plastic coat hooks that hang over
a door, also from Walmart.
3.A thin, but strong load strap. Get a Black one or
one that blends in.
4.Two 21" bungees
5.A 21" Tarp strap
6.Some bolts and nuts
7.Curtain rail (Standard on truck)
8.Philips 29in LED Smart TV
Run the load strap through the Curtain in a way that
both hooks will hang even at the level you want the
TV to be raised from the floor(This might seem easy,
but might not be). Also, you might need to take the
end piece off the curtain rail to slide the load
strap through, but don't loose the lil sliding
pieces in the rail because you will need to rest the
load strap on top of them at each end to prevent it
from falling out.
On a side note, you (may) need to reverse the way by
which the load strap fits together. Make it so that
the hanging hook does NOT slide down easy and that
pulling on the slack will actually raise the hook.
When the load strap hooks are properly level and
spaced apart close to the length of your TV screw
and tighten bolts into the curtain rail right next
to the sliding things so that they support the load
strap and DON'T slide.
Pull on the load strap to make sure it's sturdy. I
should also note that before doing any of this, pull
on the curtain rail to make sure it too is secured.
Sit the TV on the orange hooks. The hooks should
cradle the TV and also not allow it to slide.
Turn coat hooks upside wrap load straps around them
once and clip them to top of TV to hold it from
tipping over. Put Bungees through second holes on
the orange hooks and pull them over the coat hooks
to hold them down. Attach one end of tarp strap to
load lock hook and attach other end to someplace on
the truck to make the TV twist towards the place
you're going to be sitting.
Levitating TV Mount
Discussion in 'Trucking Electronics, Gadgets and Software Forum' started by MothaTrucka69, Aug 9, 2013.
just seems like a lot of useless work to achieve not much more than just mounting it right below where you had a nice flat surface and you can strap it down where you dont have to move and unhook it all the time
A21CAV Thanks this. -
Way to much. I have a 13.3 flat screen led with a stand so I can set most anywhere in my truck and use Direct tv.
I don't even use the tv cabinet anymore since flat screens came out. I depending on size and weight of your specific tv, I was able to mount mine on the wall at the foot of the bed using 4 of those small bungees and the ledge where the top bunk lays down and rests on on the wall. Works like a charm. Doesn't move, vibrate, rattle etc and has never fallin' down. This is in a freightliner though. Down side is to use the top bunk you have to move it but in my case I'm good since I never use it.
Also, because it's hanging it does NOT have to be moved or unhooked. It's perfect as is and clears a LOT of space for me to use the refrigerator top to cook on or use as a desk. If I do ever want to take it down, because all of the pressure is applied by gravity all I have to do is lift it up and it's out of the mount. So I bet now you're thinking, "..yea, I totally knew that." -
there are options out there
http://www.dieselboss.com/mountindex.htm
http://www.tedslist.com/TRUCKER-TV-...-to-be-used-in-semi-sleepers-4C4777AAF938FBD5
1st option uses the existing bolts of your seat and its easy removal plus you can buy and customize it further
2nd option is meant for the sleeper
another option if you have a top bunk you can get a hanging one that hooks to the top bunk and hangs down to the lower one and you can strap it tight against the wall
Also you can get a wall mount and mount it where there is carpet and when you remove it the bolt holes are covered up
I have seen a lot of options, I am just saying the one you used just doesnt fit all drivers imo -
Very interesting. I had something similar to that a couple of years ago. I attached a pole to a Ram Mount base, that slides under the passenger seat. I attached a pole mount to the pole and then tV. The pole was 5 feet so it was way up there and I had bungee cords running to the pole to keep it steady while driving.
Currently I built a wood frame and strapped it down in the tv cabinet. Don't have a url for the image of the wood frame. But this is how it looks when looking at the tv. It also swivels out so can watch from drivers seat or sleeper berth.
