Levelling valve issue
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by EWV, Sep 16, 2017.
  1. EWV
    EWV Light Load Member
    80
    27
    Mar 22, 2016
    Hi guys
    Kw w900l 2006
    It was riding and leveling no problem. Went for its safety and was told the levelling valve had an air leak and it was replaced.
    Now have the following issues....
    1 - Collected the truck and it looked alot higher than usual over the drives
    2 - the weight gauge in the truck is now out quite a ways from where it was before eg empty was on 20 now about 25 psi....loaded where it would usually be about 70 it's now 80+ on the gauge
    3 - loaded up and ride height seemed to be better. Unloaded and the ride height didn't automatically adjust like it should nor did the weight gauge change in the cab. I had to dump all the air out of the truck for it to go down and air it back up
    The mechanic who did it is scratching his head saying I dont know ffs
    Any ideas would be greatly appreciated
  3. GrapeApe
    GrapeApe Road Train Member
    2,215
    2,211
    Jan 7, 2013
    Well, you know that the leveling valve was changed and that's when the problem started. So there's a 99.99% chance that's where the problem is. There are two possibilities. 1 - It was riding low and the mechanic set it to the correct spec, so now it's higher, but where it belongs. 2 - It was at the correct height and the mechanic set it too high.
    Now you need to get the correct ride height measurement and check where it is to know which one.
    flood, misterG, EWV and 2 others Thank this.
  4. thaistick
    thaistick Road Train Member
    1,416
    1,737
    Dec 7, 2014
    OTR/Thailand
    ∆ what he said.
    EWV and Justrucking2 Thank this.
  5. EWV
    80
    27
    Mar 22, 2016
    Yep guessed it was due to the new valve but why even if he's set the new ride height too high / or correct does it then "go down to correct height" when I dump the air and air back up?
  6. EWV
    80
    27
    Mar 22, 2016
    Does anyone know why a newly installed levelling valve will not lower a truck back down to correct height once the load has been removed.....I have to dump all the air and air the truck back up ?
    The trucks ride height seems higher than it was anyway so will be getting that checked out to see if it's corrext.
    Thanks
  7. Goodysnap
    Goodysnap Road Train Member
    3,694
    8,948
    Jul 12, 2017
    Make sure the exhaust port is open. If plugged off it will air up and not let down once the load is off.
    EWV, Oxbow and AModelCat Thank this.
  8. JimmyWells
    JimmyWells Road Train Member
    1,000
    1,078
    Apr 7, 2016
    Could also have gotten a defective valve right out of the box.
    flood, EWV and Oxbow Thank this.
  9. m16ty
    m16ty Road Train Member
    2,265
    4,942
    Jan 22, 2016
    The leveling valve is real simple. It's basically just a valve with a adjustable arm that goes down to the axle. The adjustable arm controls your ride height. Your ride height should remain constant, loaded or unloaded. If the valve is not defective, it should always return to the same height, if you dump the air and air it back up.
    EWV Thanks this.
  10. Justrucking2
    Justrucking2 Road Train Member
    3,211
    4,292
    Sep 12, 2017
    Plymouth MI
    In other words, check that the arm is set correctly. Some trucks have known issues with the leveling valve arm.
    EWV Thanks this.
  11. uncleal13
    uncleal13 Road Train Member
    3,797
    6,293
    Apr 9, 2009
    Humboldt, Sk
    I had one done once, if would not release any air, only add air, so after a while the suspension got a lot higher.
    I found that they put two of the lines in backwards, reversed the lines and it worked good after that.
    EWV Thanks this.
