Let's talk grease, what is the best one on the market and why?
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Pamela1990, Nov 10, 2021.
  1. Pamela1990
    Pamela1990 Road Train Member
    1,820
    10,715
    Nov 7, 2021
    B.C. Canada
    What is the best grease to keep in our gun, sold at Chevron, Esso, or Petro Canada?
    Is the white waterproof stuff good for all around use on the truck and trailer? Or only for something like an ATV running in the mud all the time?
    Do slack adjusters really require some special grease?
    Do you slap anything handy on the 5th wheel?
    Flint1 and D.Tibbitt Thank this.
  3. D.Tibbitt
    140,811
    I like Marine grease . but that's just all ive ever used when running equiment and now trucks... Use the same on the 5th wheel.
    Flint1 and Pamela1990 Thank this.
  4. Arctic_fox
    3,861
    19,414
    Sep 16, 2016
    I always use the green lucas stuff for my gun and keep a bottle of lucas 5th wheel lube for my plate. If i run out i use a good lithium grease on it instead. Ive tried a few mixes but the above seems to work best
    Flint1, D.Tibbitt and Pamela1990 Thank this.
  5. JonJon78
    JonJon78 Road Train Member
    7,041
    37,553
    Jul 1, 2018
  6. Pamela1990
    1,820
    10,715
    Nov 7, 2021
    B.C. Canada
    Always used whatever dad had in the shop.
    Going out on my own soon, would like to be using quality grease, not what is on sale, with no thought to quality.
    Deezl Smoke, Flint1 and D.Tibbitt Thank this.
  7. Flint1
    Flint1 Road Train Member
    1,137
    9,748
    Sep 4, 2019
    Alberta
    I use mobil epic semi synthetic grease. Works great in our cold climate. Can still grease the truck when its cold.
    PdsDetailsPage
    Isafarmboy, Pamela1990 and D.Tibbitt Thank this.
  8. SmallPackage
    5,273
    16,442
    Dec 20, 2019
    Marion Texas
    Sorry couldn’t resist.
    On a serious note. Down here where it’s at least 90 degrees 10 months out of the year and triple digits are common for 7 of them Mystik JT6 or Schaeffer’s 274 seem to be the only two that will not melt away. The JT6 is as common as white volvo’s down here. You can get it anywhere.
  9. Pamela1990
    1,820
    10,715
    Nov 7, 2021
    B.C. Canada
    I would really miss climbing up like a monkey, and sticking the grease gun in the exhaust stack though. Then climbing up again 15 minutes later to retrieve it.
    Said with sarcasm.
  10. Joyce's Volvo
    Joyce's Volvo Light Load Member
    96
    132
    Jun 28, 2016
    Most all grease is better than no grease, however, not all grease is the same. A Manufacturer will make different styles ( grades ) of grease for different applications , wet area, low pressure, high pressure , extreme pressure , each will have some different additives ( Molly, tack )for the application to be used for. Use a good quality grease and stick with it, I don't like to mix brands for one may change the property of one or both. D. A. , Mobil , Exxon , just to name 3 , I like the Mobil CM , it's orange color and has served me well on many different pices of heavy equipment . But, it's a heavy grease ( thick ) and stays where I put it, u- joints could maybe use a little lighter grease. But, I use it through out the truck and have not seen any problems. The trick is to use a little grease often - not a lot seldom, what runs out on the ground is wasted. Colder areas may need a lighter grease and they make one for that, talk to a dealer and tell them your application and I'm assured they can give you info so you can make a better choice .
    Pamela1990 Thanks this.
  11. Pamela1990
    1,820
    10,715
    Nov 7, 2021
    B.C. Canada
    Definitely want one grease for everything. I grease a lot,
    jason6541 and Oxbow Thank this.
