Let's end the misinformation regarding steer axle weight.
Discussion in 'Experienced Truckers' Advice' started by plant, Nov 5, 2014.
  1. plant
    plant Heavy Load Member
    806
    699
    Sep 21, 2012
    Los Angeles, CA
    My steer tires are load range H Michelins rated for 7160lbs each in a "single" configuration.
    The tires are 10.826 inches wide (275mm).
    My steer axle is rated for 13,300lbs according to the sticker on the door jam.
    The distance between my steer axle and front drive axle is more than 10 feet.
    For the 12k/12.5k MAX folks (there are a lot of you from the searching I've done), show me one single state or federal law stating that my maximum legal steer axle weight is less than 13,300lbs assuming all other axle weights are legal and I am under gross.
    In California, according to the CHP officer I spoke with personally, they go by the lesser of the tire weight rating or 20,000lbs only. They do not consider the axle weight rating of the truck manufacturer, although I was advised that exceeding 13,300lbs in my case was unsafe, but not citable.
    On an unrelated note, I am considering LTL and fuel carriers in the so cal San Fernando valley. Please PM me leads or recommendations if you have one.
    123456 Thanks this.
  3. mattbnr
    mattbnr Road Train Member
    1,950
    837
    Aug 19, 2010
    Tama,Iowa
    Your steer weight by federal regulations is 20000 lb.
    now having said that your only allowed up to your axle or tire rating which ever is lower. In your configuration your allowed 13300 because you axle is rated lower than your tires.
    Also side note check your tire pressure weight rating because the weight changes according to pressure.
    123456 and plant Thank this.
  4. 315wheelbase
    315wheelbase Heavy Load Member
    783
    601
    Oct 26, 2014
    you can put up to 20,000 on a single axle ,legal weight depends on the tire rating and axle rating..some states only allow 600 lbs per inch of tire width no matter what the axle and tire rating is
    plant Thanks this.
  5. plant
    806
    699
    Sep 21, 2012
    Los Angeles, CA
    I have heard this, can you please name these states? I've seen 620, 650, but not 600. I'm also unclear about whether they round up, round down, or use the exact width.
    Assuming the worst case scenario, rounding down to the nearest inch, and 600lbs per inch, I would be limited to 12,000lbs. But I need proof that this is the law anywhere.
  6. plant
    806
    699
    Sep 21, 2012
    Los Angeles, CA
    A quick google search comes up with MN, OR, WA as states with a 600lb per inch steer tire weight limit. Does anyone know if they round up, down, or use the exact measurement in this calculation?
  7. FatDaddy
    FatDaddy Road Train Member
    4,314
    10,375
    Dec 23, 2008
    Katy, TX or Swedesboro, NJ
    The reason why 12,000 lbs on the steers has been ingrained in people's heads (mainly rookies) is because of the math.
    Since most states (not all) is 34K on drives and tandems it's just simple math.
    80k - 34k - 34k = 12k for steers. It just comes down to the easiest way to teach it.
  8. purpleprime
    purpleprime Medium Load Member
    681
    720
    May 30, 2013
    spickard, mo
    Check your atlas Minnesota Nevada Oregon south Dakota Vermont are all 600 per inch of width north Dakota is only 550 per inch
  9. plant
    806
    699
    Sep 21, 2012
    Los Angeles, CA
    I'm also reading that the "pound per inch" rule only applies to heavy haul/permit loads with super singles. And only applies on state roads. For non-permit interstate driving, you use the tire mfg's rating. Any input?
  10. purpleprime
    681
    720
    May 30, 2013
    spickard, mo
    who puts super singles on their steers?
  11. plant
    806
    699
    Sep 21, 2012
    Los Angeles, CA
    I believe that what most people refer to as super singles are actually "wide single drives" and super singles have traditionally referred to the beefy steer tires you typically see on heavy haul applications and cement mixers.
    Either way, I'm referring to the beefy steer tires.
