Legally moving a wrecked trailer to a salvage yard or from one?
Discussion in 'Trucking Industry Regulations' started by Joeziah, Nov 6, 2023.
  1. Joeziah
    Joeziah Light Load Member
    176
    131
    Jan 2, 2016
    Title says it all, there is a wrecked dry van sides collapsed in and strapped together.
    It pulls decently strait, brakes and tires are good but there is some floor damage etc.
    I want to pull it 40 miles to my house from the salvage yard in Missouri. Do they make permits for this, do they only allow registered towing companies to do this etc?
    Curious because its an almost new trailer that shares a lot of parts with my current trailer...
  3. Cat sdp
    Cat sdp . .
    20,819
    71,604
    Apr 8, 2012
    Orion's Belt
    A towing company must be able to drag it over …even if it’s not registered or insured.
    '88K100 Thanks this.
  4. Joeziah
    176
    131
    Jan 2, 2016
    Any reason? Do they have a special permit to pull a vehicle that would not pass an inspection?
  5. Cat sdp
    Cat sdp . .
    20,819
    71,604
    Apr 8, 2012
    Orion's Belt
    They must …. How else can they tow you away if your put out of service at a scale ?
  6. FLHT
    FLHT Road Train Member
    1,329
    2,260
    Aug 2, 2014
    You must remember that the strength is in the side walls.
    Had a shop foreman who was going to make a flat bed out of a van that had been on its side.
    Sounded like a good idea started cutting back to front.
    Got first side off when he got just in front of landing gears floor buckled and fell onto the ground.
    Off to the scrap yard when he finished it up in a dumpster.
    MACK E-6, W923 and Joeziah Thank this.
  7. Ffx95
    Ffx95 Road Train Member
    1,368
    2,627
    May 18, 2017
    I think it’s just that they have the proper insurance if something does go wrong they’re normally pulling damaged equipment they pay much higher insurance premiums vs you towing it yourself the insurance will deny the claim since you were pulling a trailer that you knew was damaged and they haven’t taxed you properly for the extra coverage. That and the state troopers can rag on you for faulty equipment but they can’t really do it to towing companies atleast for whatever they’re pulling not sure if they can mess with the wrecker truck itself. Honestly if it’s just 40 miles I’d get a buddy to run the route in a PV and see if they see any cops then when it’s clear run it.
    W923 and '88K100 Thank this.
  8. '88K100
    '88K100 Road Train Member
    1,247
    2,619
    Aug 23, 2020
    We have all seen wrecked trailers being towed down the road,,no way we could get away with that. Its not even kosher to move a trailer with caged brakes unless its a emergency to move trailer and hauling a trailer 200 miles to make a on time delivery does not qualify as emergency regardless of what dispatch tells you.
  9. Ridgeline
    22,098
    113,138
    Image would help.
  10. buzzarddriver
    3,507
    10,013
    Feb 1, 2011
    Dallas, TX
    That only works if the buddy has a black Trans Am and his name is "Bandit".
    bzinger and Phoenix Heavy Haul Thank this.
  11. wis bang
    wis bang Road Train Member
    3,348
    3,916
    Jan 12, 2011
    Levittown, PA
    We moved a vacuum collapsed tanker from NJ to the repair facility in Berwick, Pa. sucked in and twisted but 7 0f 8 wheels touched pavement and the lights worked...no problems. Hale trailer moved a low-bridged van back to their shop, kinda looked like a convertible...
    W923 Thanks this.
