I'm having a bit of an argument with my breakdown dept. I am being told this tire is legal with this flat spot since it doesnt reach over into the 2nd set of tread grooves on tire. Any insight?![]()
Legal tire?
Discussion in 'Trucking Industry Regulations' started by Jorihe84, Sep 21, 2014.
I know of d.o.t. officers in my area that would look for a spot like that & gauge it & if it below specs, you got written up. the last time I got inspected the officer placed his tire gauge in several places on the same tire, trying to find a low spot such as in your pic. some d.o.t. may not see it as a big deal. depends on who ya get & his mood or quota, that they don't have, Yeah right.
I fully acknowledged to them that many DOT officers will overlook it but once one of them doesn't, it's on me
the rule on drive or trailer is "less than 2/32 on two or more adjacent grooves. technically your guys are right. but not to change it is stupid. at least groove the thing with an iron
I've hauled many like that. I check depth with my gauge if less than 2/32 I'll report or if on more than one row of tread I'll report it.
My understanding is that any area on the tire that is less that 2/32" (on the trailer) is bad / needs to be replaced / is in violation.
If a new tire, even with 10 miles on it, has a flat spot & measures less than 2/32" in that flat spot, it has to be replaced. -
If you're working for a company that thinks that's ok you need to move on to another job.
finbyrd Thanks this. -
Tire/wheel clearance
Any condition, including loading, causing body or frame to contact tire or wheel assembly at the time of inspection. Evidence of prior contact is not a defect.
Steering axle of power unit
Less than 2⁄32-inch tread depth at two, adjacent, major tread grooves anywhere on tire.
Portion of breaker strip or casing ply visible in tread.
Sidewall cut, worn or damaged, thereby exposing ply cord.
Labeled Not For Highway Use or other marking excluding current application (excluding farm/offroad vehicles briefly on the road).
Bump or knot suggesting tread/sidewall separation. Exception: Bulge from section repair (sometimes identified by adjacent, blue, triangular label) is not a defect unless higher than 3⁄8 inch.
Tire has leak thats felt or heard, or has 50 percent less of the maximum inflation pressure marked on the sidewall.
Mounted/inflated so tire contacts part of vehicle.
Tire overloaded, including overload resulting from underinflation. Exception: Does not apply to special-permit vehicle operated at a speed low enough to compensate for underinflation.
If a passenger-carrying vehicle, regrooved, recapped or retreaded tires.
Other than steering axle
75 percent or more of tread width loose or missing, in excess of 12 inches of tires circumference.
Less than 1⁄32-inch tread depth at two, adjacent, major tread grooves at three separate locations around the circumference of the tire at least 8 inches apart. With duals, both tires must have listed defect to warrant Out-of-Service judgment.
Tire has leak that can be felt or heard, or has 50 percent less of the maximum inflation pressure marked on the sidewall.
Bias-ply tire with more than one ply exposed in tread area or sidewall, and the exposed area of sidewall or top ply exceeds 2 square inches. With duals, both tires must have listed defect to warrant Out-of-Service judgment.
Radial tire with more than one ply is exposed in the sidewall, or two or more plies are exposed in the tread area and the exposed area of sidewall or tread exceeds 2 square inches, or damaged cords are evident in the sidewall up to 2 square inches. With duals, both tires must have listed defect to warrant Out-of-Service judgment.
Mounted or inflated so tire contacts part of vehicle or, in the case of a dual assembly, its mate.
Tire overloaded, including overload resulting from underinflation. Exception: Does not apply to special-permit vehicle operated at a speed low enough to compensate for underinflation.Last edited: Sep 21, 2014
123456 Thanks this. -
Skateboardman -- where is that from? Edit: nevermind I found it -- it is the CVSA out of service criteria. You can still be cited for less...
Here is what 49 cfr 393.75 has to say:
Steers:
semi retired semi driver Thanks this.
