LED replacement side lites?
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Hanadarko, Aug 13, 2010.
  1. Hanadarko
    Hanadarko Independent Owner/Operator
    2,962
    927
    Oct 1, 2009
    Midwest
    I want to replace the front side marker lights my W900 (on the tops of the fenders) with LED units.
    But I haven't found LED units with a similar setup.
    My current lights (OEM) have little side bulbs in them to show up instead of the entire assembly, unless I have the blinkers on.
    Anyone know if someone makes an LED model that closer matches the KW style?
  3. 112racing
    112racing Road Train Member
    1,384
    20,548
    Nov 30, 2008
    pocono's, pa
  4. Ken
    Ken Couch Commander
    1,768
    11,941
    Oct 29, 2006
    If you change your turn signals to LED there's a good chance you'll have to get a flasher that's LED rated...
    I switched all my lights to LED's and the original flasher wouldn't work.
    Hanadarko Thanks this.
  5. Hanadarko
    2,962
    927
    Oct 1, 2009
    Midwest
    thanks!
    I also found something similar at Iowa80. But why would you want YEL/RED when the OEM was YEL/YEL ?
    Most are YEL/RED and I dont see why? :biggrin_2558:
  6. EmersonSC
    EmersonSC Light Load Member
    155
    26
    Mar 12, 2009
    Taylor, MI
    Did you switch out the whole base, or did you switch the incandescent bulbs with LED bulbs?
    If you replaced them with LED bulbs, where did you get yours? I have an International 9200i that i want to change out the front and side turn signals with LEDs but not sure where to get any
  7. lovesthedrive
    lovesthedrive R.I.P.
    15,953
    54,483
    Nov 11, 2008
    Sorrento Maine
    Yellow on the front, red to the rear of the truck. I have had a few 3 ton trucks that were set up this way.
  8. 112racing
    1,384
    20,548
    Nov 30, 2008
    pocono's, pa
    if the front and rear are only illuminated when the signal is on all yellow is ok......if the front and back are lit up as running lights the rearward facing light must be red
  9. Hanadarko
    2,962
    927
    Oct 1, 2009
    Midwest
    Well so far what I have found was that these ground thru their housing. Which is odd since they are plastic and mounted to a fiberglass fender !?
    I am also looking for replacement bulbs for the OEM KW Cab Lights on top. Wondering if such a thing exisits, instead of replacing the entire fixture?
  10. upallnite
    upallnite Light Load Member
    165
    115
    May 15, 2010
    Hempstead,TX
    ck out this web site www.fleetoilandtrucksupply.com. maximma has some pretty cool lights that should work. and I think I saw the cab lights your looking for.
  11. 112racing
    1,384
    20,548
    Nov 30, 2008
    pocono's, pa
    should be 3 wires
    white = ground
    black = running / marker
    red = signal flash / brake
    thats the standard wiring for all multi function lights
