Led headlights 389 issues
Discussion in 'Peterbilt Forum' started by joey0921, Nov 7, 2018.
  1. joey0921
    joey0921 Bobtail Member
    10
    5
    Nov 7, 2018
    I have a 2009 Pete 389 and currently have oem headlight housing with led bulbs. Everything works fine. Decided to order all aftermarket headlights for a brighter style instead of just bulbs. Once plugged in and you start the truck. The bright indicator starts flashing and the brights turn on also when on dim. Click onto bright and works like it should, then try go back does it again. I installed resistors to the power wire for the dims and then other end to ground like they are suppose to be hooked up. Now they will last maybe 20 seconds before indicator starts flashing again. Any ideas what to try next? Maybe a rectifier diode of some sort from what I have read? Thanks.
    ArturoNavejas and KB3MMX Thank this.
  3. pavrom
    pavrom Road Train Member
    3,162
    7,247
    Apr 29, 2012
    NE illinois
    ... probably needs error cancellers....had same issue on BMW with cheap bulbs ....don't use led .. they don't heat the housing , you not gonna see anything during snow
  4. joey0921
    10
    5
    Nov 7, 2018
    I have them on my other trucks and have no issues with them. Even during the snow. They are bright enough to make up for it.
    KB3MMX Thanks this.
  5. pushbroom
    pushbroom Road Train Member
    1,777
    7,253
    Sep 1, 2012
    Might need to enable led headlights in the CECU.
    Most times anti flicker modules need to be installed as well
  6. joey0921
    10
    5
    Nov 7, 2018
    I ordered a set so I will try them! You think I will still need the resistors hooked up along with the anti flicker modules?
  7. CraigInReston
    CraigInReston Light Load Member
    137
    134
    Apr 6, 2017
    Message Heavyd. He is really good with electronic issues.
  8. pushbroom
    1,777
    7,253
    Sep 1, 2012
    I would try without the resistors first and just the anti flicker modules.
    Paccar released factory anti flicker modules for the 520 with led headlights. I am wanting to try a pair out on my next install
    KB3MMX Thanks this.
  9. joey0921
    10
    5
    Nov 7, 2018
    Okay thank you! I will let you know I end up doing!
  10. Tall Mike
    Tall Mike Road Train Member
    7,244
    33,725
    Aug 20, 2014
    New York State
  11. KB3MMX
    KB3MMX Road Train Member
    3,069
    2,588
    Dec 29, 2014
    Orrstown, PA
    Do you have the part # ?
    Thanks
