Learning trucks! Single axle vs tandem or double axle truck?
Discussion in 'Ask An Owner Operator' started by jpeters72155, Feb 16, 2015.
  1. jpeters72155
    jpeters72155 Light Load Member
    219
    18
    Sep 17, 2014
    Sorry if this is like asking if a Corvette has a V8 in it or not but what are the main differences between single vs tandem or double axle semis? I already used the forum search and google just gives me a bunch of for-sale websites.
    How much does a single axle truck weigh usually? Just the truck
    What is the max weight a single axle can successfully haul? What the math and paper says is usually not the real world result, you know
    Do single axle trucks get better MPG than tandem? Im guessing yes since they are lighter but Im still learning trucks.
    What are the normal work applications for single axle trucks? I noticed the difference in HP in some single axle trucks are big, like 330 vs 425 so it looks like theres some variety to this.
    Im trying to figure out if we can move away from tandem double axle trucks to single. Small operation, we haul just dry freight locally in regular 53 foot trailers so total axles would be 4. Sometimes the max freight weight is 30-40,000lbs Thanks forum members.
  3. jpeters72155
    219
    18
    Sep 17, 2014
    Does this math seem right to you guys?
    12,000lbs per steer axle + 20,000lbs for a single drive axle = 32,000lbs.
    Those 32,000 + 34,000 tandem trailer axle = 66,000 lbs, pretty much the max GVW of a single truck axle.
  4. BUMBACLADWAR
    BUMBACLADWAR Road Train Member
    1,899
    1,923
    Dec 5, 2013
    Well,I think the other guy is accurate.Believe its 32,000 max in a 53'. Ive drove single and double axle.Frankly,double axle tractors ride a lot better on the road and are more "controllable" in the wind on washboard or "rutty" roads. Usually slightly better fuel mileage out of a single,but with a light load in the wind you find yourself babysitting the wheel and will keep you compensating a lot. Singles are great for crazy back ins in tight parking lots. Prefer a double for ride quality.Also singles suck for slick mountain passes,barely any traction and will "break traction super easy".Put it in interlock with a double axle and chains and you're golden. That extra set of axles helps tremendously. I dont really care for single screw tractors. JMO
    cellopudding Thanks this.
  5. KANSAS TRANSIT
    KANSAS TRANSIT Road Train Member
    4,080
    6,845
    Jul 28, 2011
    Glasco,Ks.
    We run 9 S/A sleeper trucks nationwide, trucks are Cascadias with 410 hp, we also run 53 trailers. We lic. for 54,000 so my combo works out to 12,000+20,000+ 38,000 (we run an 8' spread axle, so we pick up 4,000 on the spread) The reason we run more axle than we reg. for is because of what we haul, we can not usually shift cargo, slide axles or slide 5th wheel.
    With that said, we will be going to a 3 axle setup soon, 12,000_20,000_20,000, BUT the new trailers are lighter than what we are running now, so I think we can pull it off.
    I personally like the S/A tractor, better mileage, less weight, less rolling res. less tire cost, less maint. less tolls, better turning, etc.etc. As far as traction being better on a twin screw, it depends, remember something, IF you have a bottom, hard packed surface you actually have MORE weight per tire on that S/A (at max weight) that you will on that twin screw.
    Also remember, MOST twin screws run an interlocker, BUT they don't run locker rears, so on a very slippery surface, even in diff lock, you ONLY have two wheels turning, give me a S/A with a true diff locker and I will go places that will make your head spin.
    Now if you have no hard surface, sand deep mud etc. then yes the twin screw will have better flotation. As far as weight, my Cascadias are 60" sleepers and are hard loaded, APU's, power everything, AMT's reefers, swivel seats, etc, they weigh 16,000 I think you could get one down to 14,800 pretty easy.
    Hope that helps?
    BeN DaViS, brian991219 and Cetane+ Thank this.
  6. jpeters72155
    219
    18
    Sep 17, 2014
    Thanks for the info. Luckily if we get singles they would be on concrete roads all the time. We operate near a major city.
  7. jpeters72155
    219
    18
    Sep 17, 2014
    Yeah, that definitely helps. That's a lot of good info, thanks so much.
    Can you explain this a bit in more umm lamen terms? "Also remember, MOST twin screws run an interlocker, BUT they don't run locker rears, so on a very slippery surface, even in diff lock, you ONLY have two wheels turning, give me a S/A with a true diff locker and I will go places that will make your head spin."
    What's an interlocker? What are locker rears? What I get from this is that 2 axle trucks don't ever have all 4 tires spinning per axle, just 2 tires per axle. Is that what you mean?
    And luckily we'll have hard surfaces all the time. What do you think of using s/a's for local city pickups with some highways all going back to a main warehouse using 53 foot trailers, always dry freight and usually on pallets? max freight weight of 40,000lbs and that's probably 50% of the time. If those s/as weight about 15,000 we'll say, the 40,000 load seems possible no? Even if the trucks can do it, do you think that sort of weight is going to lead to too much wear and tear because its a s/a instead of a tandem? You did say less maintenance overall but I dont know what other variables are involved under your use.
    Thanks again, this info could really help out our small operation. We are trying to grow :]
  8. Ridgeline
    22,853
    126,487
    I'm wondering have you talked to a dealer who can see your operation and help you make a good informed decision?
    Normally they would be the first one to talk to seeing that they can see what you are hauling and how it is being hauled.
  9. KANSAS TRANSIT
    4,080
    6,845
    Jul 28, 2011
    Glasco,Ks.
    Well, let's start with the weight first, because if you can't scale or axle it, nothing else really matters,
    Let's say you get S/A tractors that weigh 15,000 and let's say your trailer weighs 15,000 (I'm guessing here, any idea what your trailer weighs) that puts you at 30,000, even if your trailer is a bit lighter you still have fuel, driver, etc.
    So if your combo is 30,000 ready to roll empty and you add 40,000 you will be at 70,000 gross, can not gross that on four axle "conventional" dry van, because you will be 12,000+20,000+34,000= 66,000, so at MAX weight on every axle you will still be 4,000 short!
    Now, you "could" run a spread axle trailer on a 10'1" and that would look like this,
    12,000+20,000+20,000+20,000= 72,000 you could make weight with this setup, HOWEVER, you would have to be almost perfect on your weight distribution, you would need a sliding 5th, and if you get a heavy ended load you could still be in trouble.
    So I guess you "could" do it, but you are probably going to have a hard time finding a spread axle dry van, AND if you are local del. you really don't want a spread axle, you would spend more on trailer tires than you would save by having one less axle on your tractor.
    You could say, OK, so I will limit my loads to 33,000 that would be doable with sliding 5th and sliding tandems, but now you are into diminished returns, how many loads will I have to split or give up at that weight?
    Just from what you have told me I am not sure it is a feasible endeavor, JMHO.
    Stan
  10. mugurpe
    mugurpe Medium Load Member
    395
    274
    May 5, 2013
    Arlington, MA
    a dealership can help you spec what you need, but also understanding things first isn't a bad idea. A couple things to keep in your head, though there are of course permutations for each but this is a start:
    single axle with single wheels on it(steer axle) 12,000 lbs
    single axle with dual wheels 20Kklbs
    tandem axle (two axles very close together, with dual wheels) 33K
    spread axle is weighed as two single axles so 40K
    underCDL straight trucks have lighter axles and are usually 10K and 16K, they tare at roughly 15K lbs
    our single axle daycab tractor and single axle pup trailer scales at 25K with a little equipment on board. GCVW for that combo is 52K
  11. jpeters72155
    219
    18
    Sep 17, 2014
    Stan, you have given me the answer because we actually can't choose to limit the loads to below 40,000lbs. They vary daily since they are for LTL loads to different states. We pick up as much freight as possible really. They dont max out at 40,000 often but because there's no choice involved really, its too much weight for a s/a with 4 axle set up, even with our trailers weighing more at 12,000.
    Then under the solution you described, you're right. I read a little right now about tire wear on the spread axles and on top of that, you're also right that I don't see any of those around. And Im reading its because for others who do have tandem axle trucks, it wont help much because they still can't load past 80,000 gvw.
    So finally I would wonder, is there such a thing as a sliding spread axle trailer but at the same time think about "Well if a spread axle is hard to find, imagine how hard it would be to find a sliding one while also needing 4-5 of them?!"
    So thats my thought process but a lot of it has been with your help. Thank you Stan!
    KANSAS TRANSIT Thanks this.
