Learning about Outriggers
Discussion in 'Heavy Haul Trucking Forum' started by Hegemeister, Sep 21, 2017.
  1. Hegemeister
    Hegemeister Road Train Member
    1,912
    1,660
    Jun 16, 2012
    Mechanicsburg, PA
    Hey y'all.
    Just purchased a double drop with outriggers. I just want to make sure I know what I'm doing when I get to the shipper.
    I have a basic understanding, but I have a few questions.
    Will any wheeled or tracked wide load still grab the trailer to get up the ramps?
    Also, will the weight of the load alone be enough to secure the boards?
    How many feet per side should I have planking for? ( 29' well)
  3. m16ty
    m16ty Road Train Member
    2,265
    4,942
    Jan 22, 2016
    As long as some of the track/wheel will be on the main deck, you can usually still get up the ramps. We usually lay blocks down at the end of the outrigger boards to climb up on and also lay the first board on the blocks to keep them from kicking up.
    As long as the weight of the machine is on the boards, they will stay put. be careful to check for loose boards that have no weight on them.
    The main thing is to overlap your boards where the end won't kick up when you start over them.
    Oxbow, sawmill and Hegemeister Thank this.
  4. Hegemeister
    1,912
    1,660
    Jun 16, 2012
    Mechanicsburg, PA
    What would be a good length for each board with a 29' well?
  5. m16ty
    2,265
    4,942
    Jan 22, 2016
    Ideally 29'. You aren't going to find any that long though and they'd probably be too heavy to handle.
    Most hardwood boards you're going to find at a sawmill are going to be 12'. You'd probably be ok with 2- 12 footers for each side.
    Hegemeister, Landincoldfire and Oxbow Thank this.
  6. Hegemeister
    1,912
    1,660
    Jun 16, 2012
    Mechanicsburg, PA
    That's exactly what I have. But they are heavy and I can't store them across the deck. I was thinking of cutting them down to 6'. What do you think?
  7. westernstarheavyhaul
    westernstarheavyhaul Light Load Member
    137
    958
    Aug 21, 2017
    Would be too short. Can't store them in the centre?
  8. m16ty
    2,265
    4,942
    Jan 22, 2016
    Yea, 6' is too short. Most people store them in the center longways.
    Hegemeister Thanks this.
  9. Hegemeister
    1,912
    1,660
    Jun 16, 2012
    Mechanicsburg, PA
    Thanks. That s what I'll do.
  10. Heavy Hammer
    Heavy Hammer Road Train Member
    1,184
    5,889
    May 1, 2013
    In purgatory
    If its your trailer, or a dedicated trailer and you want a solid investment, go get a couple lengths of aluminum C channel that is about 2" narrower than your outriggers. i.e. with 12" wide outriggers, get 10" wide C channel.
    The reason you want C channel & narrower than the outrigger is; you can use a 2" ratchet strap to tie the C channel to the outriggers so it doesn't flop around when loading/driving over, and since you've tied them down to the outside edge of the outrigger you can still drop your hooks in the 2" space and hook to the outside flange of your trailer, not removing what is usually the best tie down locations.
    Another sweet feature of C channel, you can flop one of them upside down and they interlock, thus taking up only the space of 1 outrigger plank instead of 2 when they are not in use. You also get the security that they aren't going to crack and break like planks may while in use.
    The ones I have came in 16' length, and I cut them to 11' & 5' and those lengths work pretty good. On the articulated rock trucks, (Cat 740 etc.) you have the 11's for the drives, and the 5's for the steers. Same for Graders. 11' under the centre of an excavator track covers almost the entire length of actual ground/deck surface contact.
    I have never needed to outrigger the entire length of the well, so myself I can't see a reason to require more than what I have, ymmv.
  11. Don Muirhead
    Don Muirhead Bobtail Member
    33
    46
    Aug 23, 2017
    i am obviously late. anyway id love to see some photos of using aluminum as outriggers. have they ever bent under 79k pounds on 4 wheels such as a cat loader.
    thanks
