Leaking V Band Clamp
Discussion in 'Trucks [ Eighteen Wheelers ]' started by JimmyWells, May 31, 2017.
  1. JimmyWells
    JimmyWells Road Train Member
    1,000
    1,078
    Apr 7, 2016
    The v band clamp that holds by turbo and down pipe together is leaking. I can see black soot where the bolt head is and I can feel it on the back of my hand if I hold it up to it. I've already tried tightening it up some more with a half inch ratchet but didn't want to go too far because I worried about breaking the clamp. Is it time for a new clamp or should I be looking for some RTV or gasket?
  3. Luwi67
    Luwi67 Heavy Load Member
    746
    484
    Oct 24, 2012
    Long island
    Separate the flanges and see what's going on between them. The flanges are precision ground assemblies and seems odd that they would leak.
    The outer clamp could be broken somewhere and allowed the flanges to warp possibly but either way a full disassembly would be required and everything examined to find the problem.
    V-bands are all I use when I build exhaust systems for cars, they are expensive but worth it in my opinion. They are foolproof and reliable therefore, probably used in that position behind the turbo for that reason.
    Some advise to save you and anyone else some headaches is to never touch a V-band assembly clamp with a 1/2" ratchet, they should be torqued properly (they are precision ground and just snugging them up has always worked for me) . I also use high temp anti-seize on the threads for trouble free reliable disassembly and reassembly.
    JimmyWells Thanks this.
  4. homeskillet
    homeskillet Road Train Member
    5,652
    40,906
    Jun 1, 2013
    Dayton, OH
    New clamp. If your old one is still leaking after you tried snugging it up, then you need a new one.
    I work mostly on Cummins, and I have never worked on one that has a gasket at that joint. Just check and be sure the flange is not bent, and maybe take a hand wire brush to it to knock off any crud. Don't use a whiz wheel; more is not better in this case.
    When you put on the new one, once you have tension on it, if all you have is a half inch drive, just use one finger on the handle until you can't turn it anymore. If it still leaks, one-eighth turn at a time until it stops leaking.
    Also be sure to get the correct replacement clamp. Use part numbers if possible; seemingly identical clamps can have slightly different profiles. Good luck!
  5. Luwi67
    746
    484
    Oct 24, 2012
    Long island
    If you find nothing wrong after disassembly you could use a stiff sanding block and go over the mating surfaces of the V-band flanges lightly and squarely after you color them in with some Dykem layout fluid or a sharpy marker. This will indicate if the flanges are warped if any color is left on the mating surfaces.
    If there is color left you could keep sanding lightly and squarely until all the color is gone and that should true them up enough to seal.Careful about letting debris in the turbo side.
    Don't use silicone!
    I HATE exhaust leaks.
  6. little cat 500
    2,044
    1,090
    Jan 17, 2010
    Abbottstown PA
    I tap the clamp with a hammer as in getting the bolt tight
    Diesel Dave and JimmyWells Thank this.
  7. JimmyWells
    1,000
    1,078
    Apr 7, 2016
    Put a fancy new clamp on today and problem solved! Sure is nice to not hear that annoying leaking sound anymore.
  8. Diesel Dave
    8,526
    23,502
    Jan 20, 2010
    Hesperia, Ca.
    I always get a rubber mallet or blow hammer and tape around the clamp as I snug it up. Gives it a better seal.
  9. AModelCat
    154,481
    Any time I need to remove an exhaust pipe I try and use a new clamp if possible AND clean the two mating surfaces. Any debris or rust in between the 2 surfaces will keep it from sealing correctly.
  10. JimmyWells
    1,000
    1,078
    Apr 7, 2016
    I didn't use any tape but definitely tap the circumference of the entire clamp with a rubber mallet as I torqued it down. Nice and quiet now. Quiet for a CAT that is!
