Leaking radiator Peterbilt 379
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by 3Peter7bilt9, Sep 6, 2019.
  1. 3Peter7bilt9
    3Peter7bilt9 Bobtail Member
    4
    Texas
    Had two shops recore the radiator put new seals bolts and all it’s still leaking from the overflow hose ..trucks a Peterbilt 379 with a ‘99 Cat-3406e engine truck just had a major overhaul with new parts and all so I’m really scratching my head on this one. Anyone have any idea what it could be
  3. Intothesunset
    Intothesunset Road Train Member
    2,289
    4,880
    Apr 15, 2019
    truck
    If the radiator is mostly aluminum and a few years old that could be the issue.
    Or if radiator is aftermarket some are made poorly. Or poor recore work. Have radiator leak tested.
  4. Rideandrepair
    17,212
    55,865
    Aug 8, 2015
    Leaking from the breather line? You mean overflow tube? If so, could be a bad cap. Or could be a pressurized coolant system. Sign of a more serious problem. Rule out any heater control valves, on cab or bunk that have an air line running to them. Air over electric,( or electric over air?) heater control valves were used in 99. Not sure on Peterbilt’s or not. Turning off water supply valves from water pump, will isolate it if that’s the problem. When air controlled valves go bad they will pressurize the system, often resulting in a mis- diagnosed head gasket or bad liner problem. Sounds like you need to get system pressure tested. See if it’s making excessive coolant pressure. Any shop can do it.
    Harmonj Thanks this.
  5. stillwurkin
    stillwurkin Road Train Member
    1,756
    2,856
    Dec 2, 2017
    When i had my 3406-e it would burp out coolant on a hot day as the coolant rose to a higher level in the tank. Even though it wasn't overheating. If i put the engine fan on anyway, it solved the issue. Also may add that topping the level to the very end of the filler neck made it do more burping until the level got down to its normal running amount of coolant. All other great advice, but i am hoping its something this simple like this.
